Is there a way to show a picture of the areas of a diameter that is undersized
analysis picture of undersize diameter
Measure the circle with as many points as you can (or scan it with slow speed and high point density)
Create a Circularity dimension of the circle with same tolerance as diameter.
For 1-time deal, just take a screenshot.
For an ongoing multi-part project, create an Analysis View and stick it into the report.
by HUSKYFairly new to PC-DMIS here and I was wondering how to view the high an low spots of a diameter measured using 64 points. I am freezing a bearing race...
04-04-2009, 02:40 PM -
by AuRules1) Went and measured a circle with ten points.
2) Then I created a roundness feature from the circle.
3) The I opened the analysis view....-
10-01-2008, 03:54 PM -
by keegoI did a scan on an OD and I need to print out a graphic of the form. I constructed a circle from the scan, dimensioned it with graphic analysis on, but...
06-24-2009, 09:53 AM -
by chado151Here is what I need to be able to do. I have an ID with a +/- .001" and no circularity callout. I need to be able to insure that every hit taken...
06-07-2012, 07:40 PM -
by cappy6124Hi all,
i'm trying to use a graphical analysis to show our polishers where they need to hit a part, unfortunately after the analysis...-
02-29-2012, 10:27 AM -
