resolved
Needing help, Having issues
Code:PLN5 =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<-0.6081,0.0669,0>,<[COLOR=#FF0000]0,0,1[/COLOR]> ACTL/<15.4021,12.9553,-31.3072>,<[COLOR=#FF0000]0.0000838,-0.0000649,-1[/COLOR]> MEAS/PLANE,6 HIT/BASIC,NORMAL,<-1.6156,5.8424,0>,<0,0,1>,<9.866,11.5325,-31.3077>,USE THEO=YES HIT/BASIC,NORMAL,<4.2609,4.1547,0>,<0,0,1>,<11.7193,18.7349,-31.3079>,USE THEO=YES HIT/BASIC,NORMAL,<4.598,-3.8334,0>,<0,0,1>,<19.3134,18.7349,-31.3071>,USE THEO=YES HIT/BASIC,NORMAL,<-1.3445,-5.9164,0>,<0,0,1>,<21.1779,12.0533,-31.3068>,USE THEO=YES HIT/BASIC,NORMAL,<-4.8067,-3.6496,0>,<0,0,1>,<17.4856,8.338,-31.3067>,USE THEO=YES HIT/BASIC,NORMAL,<-4.7409,3.804,0>,<0,0,1>,<12.8506,8.338,-31.3069>,USE THEO=YES ENDMEAS/ A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN5 ALIGNMENT/TRANS,ZAXIS,PLN5 ALIGNMENT/END
(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
Well either way, if the program runs who cares. The CAD model is useless at this point anyways. It has no purpose unless you are planning on adding other features to this program.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- 1 like
by B. JacobsHow would I insert a Probe Calibration command at the begining of a program?
I am working on writing a program to check the variation of...-
05-11-2006, 10:26 AM -
by David WedelWe have been dealing with this for a while. I will try to give you a brief break down. The normal pocedure for calibrating is do a mark used, measure,...
03-22-2014, 10:37 AM -
by Wally_BHi All,
I have 7 years experience with DEA's Tutor package, but am new to PCDMIS.
As I change over, the old Tutor rack...-
03-17-2009, 11:21 AM -
I have a issue where I have 6 different probes set up in a tool changer, however there is no calibration program for this machine, the calibration method...
07-31-2012, 09:09 AM -
by garnerjI'm having trouble calibrating a probe. It shanks out on the A0B0 tip angle. How do I raise the level at which the tip hits?
06-10-2013, 09:21 AM -
