This has been plaguing me for eons.
It's kind of like the first time an optometrist corrects your vision and you realize you've been dealing with crappy vision up until that point... Well, I've had this issue with 2012MR1, and I just realized that on 2018R1 SP7 IT STILL PERSISTS. What the efffff Hexagon? How can you not fix this after over a dozen releases?
Here's the situation:
write routine.
add assignments
add file/writelines
hover over anything prior to executing, and it will give you the little box showing the resultant output for assignments or writelines.
execute the routine, and hover your cursor over ANY assign or writeline, even inadvertently, and you get this silly error pop up. "Encountered an improper argument" you have to click OK on to continue.
it makes doing any changes to assigns or writelines a fricken game. let's see how quickly you can move cursor to where you need it, click to place cusor then move mouse away from all other assigns or writelines, or else! bah! /endrant.
write routine.
add assignments
add file/writelines
