Today while running a normal tip calibration the machine stopped after some of the probe rotations, this was not good because it had not finished up before the morning runs.
tip calibration stall
I have had a few times where I use DCC+DCC and the first four initial hits it takes to center the ball at certain angles. It would take 1 maybe 2 out of the 4 hits then stall. I would just do a total reboot, home the machine and the hiccup was gone.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
do you have probe enable button switched off? so I recently got a scanning probe (if I recall correctly you have the same one I do, a Leitz LSPX1H_T) and learned that the "probe enable" button we once knew would effectively disable the probe's touch detection, is now a probe "rebalance" toggle, and must ALWAYS be illuminated on when running.
Oh click and continues? Older machines usually don't rotate around the ball so good. Set your Prehit Retract a little higher. I have a Brand spanking new machine, and I have an older Brown&Sharpe early 2004, I believe. Same Program, Same Setup, Same Calibration ball, New CMM, No problems, Calibration fine, all good nice and smooth around the ball. The older one, kinda square going around the ball, has barley bumped across the ball stopping progress. Have to turn the prehit and retract up a tad. Grandpa don't make it around the corners like he used to.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
been running the same program for a year and not had any issues, the machine is a 3 year old global and I am using .050 prehit the probe is not hitting the sphere it rotates to the next position and sometimes stops.
by RobontarioHello, everyone.
I kept on getting calibration out of tolerance message last night, when I worked on a kind of DV part. The start calibration...-
02-10-2022, 02:57 PM -
by mhackman72Hi,
The probe calibration program currently on our CMM begins each tip probing in the 90 -90 position. I started to make a new calibration...-
05-21-2014, 12:24 PM -
by rangerboat72"Has the calibration sphere moved" prompt. . .
I am running a very large machine where I never have to move the calibration artifact....-
06-20-2006, 07:25 AM -
by sfieldWe got a Hexagon Metrology SF 7107 with PC-DMIS 2014 almost a year ago. Probe Calibration is run weekly with scans. I noticed recently that on at least...
09-01-2015, 10:06 AM -
I've had a program I've been running problem free for several months now. Today in between parts all the measurements went way out of wack. After eliminating...
08-10-2017, 04:29 PM -
