I'm checking a radius on a part, and only 47° of it can be probed, the radius has a .002 total tolerance on it. I understand that FIXED_RAD is often used to locate the center point, then that center point is used to do a LEAST_SQR best fit to determine the actual radius, can anybody confirm I have this right?
My question is about the legacy reporting of the FIXED_RAD best fit math, I'm attaching a clip of it. My take on this is that it does a best fit of that R1.712, tells me where the x,z location of that fixed rad is... this much I am pretty sure is correct, but unsure of the RN value... is this showing me the maximum deviation of the measured surface from the theoretical rad at the reported x,z value? Maybe oversimplifying it to say how much the fixed rad varies from the probed data using the measured center point? I'm basically wondering if I may be able to skip the second analysis of the feature if I tolerance the x and z as well as the RN of FIXED_RAD so that it still represents a functional fit of the mating part.
I know most of you cannot stray at all from drawing specs but I have pretty much total freedom in how I use the CMMs to approve a part, if I think engineering has messy datums(more often none at all) I use what works for me to measure it then make them follow that to disposition any deviations
filedata/fetch?filedataid=16587
This is my auto feature window, in case it answers any questions about my inquiry. Also how many probe points would you take to measure this radius? This one is probed as a cylinder and I am taking 12 hits per level at 3 different levels.
And a picture of the feature, the cylinder is the convex bottom of this pocket...
Gheez this post got a bit stupid... hopefully my question is clear among the rest
