I have 2 arcs and want to construct a mid arc between them. Is there a way to take the numhits between the 2 arcs and create a mid arc between them? As of right now I just have auto points taking hits on the arcs and creating a mid point between the 2 and constructing a circle out of the mid points.
CONSTRUCTING A MID ARC (vision system)
Hi guys. Its been awhile since I have been on.. Don't they have a forum section for Vision Systems? Or am I misunderstanding the two?sigpicSummer Time. Gotta Love it!
I sounded kind of douchie below. That was not my intention. I apologize for that. But, if it makes more sense, I can start posting stuff in the vision section since I am looking for a vision answers?
Daddy don't worry about sounding a little douchey. InspectorJester is a Douche, speaking to him like that is appropriate.
Maybe my eyesight is going, but I didn't see anything douchey, except from KIRBSTER269
I have not but I don't think that will work. For a curve you need a minimum of 4 features. Or if its a scan, you can only select 1 scan at a time to construct into a curve. Then I don't know if it will let you create a curve because it will only think you are selecting 2 features.
Well the idea is to do auto circles to get enough hit points to get a good average of the arc/radius on each outer edge. Then somehow be able to create a mid arc/radius. But having a loop with points is kind of a run time killer and want to avoid that. As of right now, the tolerances are lose enough where this method with just the 3 points will work and be accurate enough. But for down the road parts, I was just wondering if it was possible to do something like this.
to answer your question directly, however, you'd have to start and end your curves in the same direction (or invert array values for one of the curves).
curve1 = 4point inner curve
curev2 = 4 point outer curve
construct -> point -> mid. select curve1 and curve2
now within that point, manually type in .hit[1] after each curve feature defined.
copy/paste with pattern your constructed point 3x with nothing changed
rename the 3 additional constructed points [1] cycling up your hit array value a digit each time [2],[3],[4]
voila midpoints from two measured curves
by Jonathan SIs it possible to create a point at the intersection of an arc and a line? I tried all the options for creating points but the point is not created where...
09-18-2006, 03:24 PM -
by BrandnewTwo questions (sorry if don't make sense, my gd&t lingo isn't quite there yet):
1) Based on the attached file i just wanted to verify...-
03-31-2009, 08:44 PM -
by 1CMM4MEB&S "One" ,version 4.1 Cad
Another newbie question: Yes, I searched the other threads too.
Got a part today: It is a segment...-
07-03-2007, 07:54 PM -
by LOBBSWe've got an old part (new to us) that calls out on the print an arc length from the intersection of the mold line with -A- and the surfaces in question....
05-12-2010, 10:30 PM -
by JVau425033Is there a way in Dmis to construct a diameter using 4 arcs?
01-22-2016, 10:54 AM -
