Reporting a range
  • Reporting a range
    Can anyone explain a way to report a summary of a group of features? For example, reporting only the maximum and minimum sizes for a group of holes or the range.
    Quick answer is variables, but I'd have to do some experimentation to tell you exactly how.
    Kevin
      assign/v5=min(array(27_hiden_1.meas,27_hiden_2.meas,27_hi den_3.meas,27_hiden_4.meas,27_hiden_5.meas,27_hide n_6.meas,27_hiden_7.meas,27_hiden_8.meas,27_hiden_ 9.meas,27_hiden_10.meas))
      assign/v6=max(array(27_hiden_1.meas,27_hiden_2.meas,27_hi den_3.meas,27_hiden_4.meas,27_hiden_5.meas,27_hide n_6.meas,27_hiden_7.meas,27_hiden_8.meas,27_hiden_ 9.meas,27_hiden_10.meas))
      f5 =generic/circle,dependent,cartesian,out,$
      nom/xyz,<-0.00002,0.00017,0.00013>,$
      meas/xyz,<-0.00002,0.00017,0.00013>,$
      nom/ijk,<0.0000051,0.0000798,1>,$
      meas/ijk,<0.0000051,0.0000798,1>,$
      radius/0.2,v5
      f6 =generic/circle,dependent,cartesian,out,$
      radius/0.2,v6
        you need to use the min array and max array and then generic feature
          what thomas pilc said, but apply it to features instead of dimensions. You can also break the code down so you only need to assign the array once.
          assign/v4=ARRAY(27_hiden_1.R,27_hiden_2.R,27_hi den_3.R,27_hiden_4.R,27_hiden_5.R,27_hide n_6.R,27_hiden_7.R,27_hiden_8.R,27_hiden_ 9.R,27_hiden_10.R)
          assign/v5=minindex(v4)
          assign/v6=maxindex(v4)
          assign/v7=v4[v5].all
          assign/v8-v4[v6].all
          (don't recall if .all works or not. If not you can use .xyz and another for .ijk, and another for .r)
          Then create your generic representations of them
          nom/xyz,<v7.tx,v7.ty,v7.tz>,$
          meas/xyz,<v7.x,v7.y,v7.z>,$
          nom/ijk,<v7.ti,v7.tj,v7.tk>,$
          meas/ijk,<v7.i,v7.j,v7.k>,$
          radius/v7.tr,v7.r
          nom/xyz,<v8.tx,v8.ty,v8.tz>,$
          meas/xyz,<v8.x,v8.y,v8.z>,$
          nom/ijk,<v8.ti,v8.tj,v8.tk>,$
          meas/ijk,<v8.i,v8.j,v8.k>,$
          radius/v8.tr,v8.r
          [/CODE]
            the reason i did the dimension and not the feature is so i can see what one fails if the min or max fails those dimensions are all hidden from report or stats
              Thank you all.
              When I assign an array from 33 circles, how can I continue listing on another line?
                If all the features / dimension have the same "name", then create a loop V1 from 1 to 33
                ASSIGN/V2[V1]="CIRC"+V1+".R" shouls work
