Trouble installing PDF drivers
  • Trouble installing PDF drivers
    We have PCDMIS 2016 and I am having trouble with the PDF drivers installing.
    I've done everything according to the readme file in the PDFdrivers folder. I ran the .bat file as an admin and here is the error message I am getting.
    Attached is the message:
    Any ideas.
    Did you unzip the files before trying to run them?
    Can you give a detailed step by step on what you did?
      When I first got this job, the pdf converter was already not working....
      So I went in, unzipped the aforementioned folder (extracted the folder to the same folder it was in)
      Ran the uninstall.bat file as admin
      Restarted
      Ran the installer.bat file as admin
      Error message I posted came up. Unsuccessful.
      I feel like Ive had this problem before in the past........Some 32/64 bit kinda issue with the dll file. Im using windows 10 on a 64 bit system.
      Just cant remember what I did to resolve.
        It cannot install the printer because it cannot find the driver.
        It cannot install the driver because access is denied.
        Are you on a company network? Maybe IT can login as Admin and setup the printer?
          CutePDF Writer is what I use. Pcdmis doesn't muck it up.
          • LouGeier
            PDF Printing Issue
            by LouGeier
            We are trying to get a finished report to print out physically from a networked printer and to create a pdf of the report as well. The PDF has to be...
            06-06-2012, 10:44 AM
          • mdcon
            Print to PDF error
            by mdcon
            I've installed PCDIMIS 2009 MR1 on a new computer a couple of weeks ago and I've been getting an error message when I try to print to a PDF file.
            04-05-2011, 10:10 AM
          • Chaddy7604
            PDF driver problem
            by Chaddy7604
            Just upgraded from V4.2 to V4.3 everything appears to run as normal until the report is sent to save as a PDF file, now getting an error window with the...
            11-25-2008, 05:43 AM
          • JVau425033
            PDF Driver
            by JVau425033
            Has anything seen this error message "unable to load PDF Driver. Is CDINTF.dll istalled correctly?". It ran fne on friday, but not today.:b...
            07-05-2011, 03:22 PM
          • wcdr99
            pdf drivers
            by wcdr99
            I am trying to find the pdf drivers. I keep getting "unable to load pdf drivers is cdintf.dll installed correctly? I got this help from support but...
            10-18-2007, 11:12 AM
