Points from a circle?
  • Points from a circle?
    Is there a way to get the points from an Auto Circle?
     cir1.hit[1].tx, cir1.hit[1].ty,cir1.hit[1].tz
     cir1.hit[1].x, cir1.hit[1].y,cir1.hit[1].z
    Just pick the points (number) and plug them in to the [#].
    Do this for each point you want to 'pull' from the circle.
      or you can assign an array of hits and go from there.
      ASSIGN/V2 = SCAN1.HIT[1..SCAN1.NUMHITS].XYZ
      Hit F1 and click on "Search" tab. Type in "Hit Arrays" for detailed info.
      • Darrollh
        Darrollh commented
        I am not sure about the earlier versions or I could be way off base but, I clicked something in setting in 2019 and I was able to see and extract the points I needed without any additional coding.
      • anthony.alfaro
        anthony.alfaro commented
        Darroll is correct. with the later versions of PCD you can do a constructed point an select individual hits from a circle feature (or any other feature for that matter.)
      Originally posted by brian.freeman View Post
      You have to create each point as a GENERIC POINT. You also need to leave the labels for each circle as CIR1, CIR2 and so on. When constructing generic features you need to leave things in the PC-DMIS syntax. Here is a sample code from a (4) Point circle;
      F1         =GENERIC/POINT,DEPENDENT,CARTESIAN,$
                  NOM/XYZ,<CIR1.HIT[1].TX,CIR1.HIT[1].TY,CIR1.HIT[1].TZ>,$
                  MEAS/XYZ,<CIR1.HIT[1].X,CIR1.HIT[1].Y,CIR1.HIT[1].Z>,$
                  NOM/IJK,<0,0,1>,$
                  MEAS/IJK,<0,0,1>
      F2         =GENERIC/POINT,DEPENDENT,CARTESIAN,$
                  NOM/XYZ,<CIR1.HIT[2].TX,CIR1.HIT[2].TY,CIR1.HIT[2].TZ>,$
                  MEAS/XYZ,<CIR1.HIT[2].X,CIR1.HIT[2].Y,CIR1.HIT[2].Z>,$
                  NOM/IJK,<0,0,1>,$
                  MEAS/IJK,<0,0,1>
      F3         =GENERIC/POINT,DEPENDENT,CARTESIAN,$
                  NOM/XYZ,<CIR1.HIT[3].TX,CIR1.HIT[3].TY,CIR1.HIT[3].TZ>,$
                  MEAS/XYZ,<CIR1.HIT[3].X,CIR1.HIT[3].Y,CIR1.HIT[3].Z>,$
                  NOM/IJK,<0,0,1>,$
                  MEAS/IJK,<0,0,1>
      F4         =GENERIC/POINT,DEPENDENT,CARTESIAN,$
                  NOM/XYZ,<CIR1.HIT[4].TX,CIR1.HIT[4].TY,CIR1.HIT[4].TZ>,$
                  MEAS/XYZ,<CIR1.HIT[4].X,CIR1.HIT[4].Y,CIR1.HIT[4].Z>,$
                  NOM/IJK,<0,0,1>,$
                  MEAS/IJK,<0,0,1>
      Marty Dobson
      Director of Quality
      http://www.linkedin.com/in/mjdobson
      PC-DMIS CAD V4.2 MR1 & V2011
      PH10MQ
      TP200
        Originally posted by mdobb829 View Post
        You have to create each point as a GENERIC POINT...
        That depends on what you want to do with them - you can for example dimension the location of a single hit just by changing the reference in the Edit Window
        Original
        DIM LOC1= LOCATION OF CIRCLE CIR1  UNITS=MM ,$
        GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  HALF ANGLE=NO
        AX    NOMINAL       +TOL       -TOL       MEAS        DEV     OUTTOL
        X      124.000      0.100     -0.100    124.000      0.000      0.000 ----#----
        Y       50.000      0.100     -0.100     50.000      0.000      0.000 ----#----
        Z      -15.000      0.100     -0.100    -15.000      0.000      0.000 ----#----
        D       44.000      0.100     -0.100     44.000      0.000      0.000 ----#----
        END OF DIMENSION LOC1
        Change to
        DIM LOC3= LOCATION OF POINT CIR1[COLOR=#FFA500][B].HIT[3] [/B][/COLOR] UNITS=MM ,$
        X      113.000      0.100     -0.100    113.000      0.000      0.000 ----#----
        Y       30.947      0.100     -0.100     30.947      0.000      0.000 ----#----
        D        0.000      0.100     -0.100      0.000      0.000      0.000 ----#----
        [LEFT][COLOR=#000000][FONT=Arial][SIZE=12px][/SIZE][/FONT][/COLOR][/LEFT]
        There's also the CIR1.NUMHITS which can be quite useful.
          Alternatively, there's an option in AutoCircle called "To Points" which will create all the hits as individual point features. From there you could construct the circle.
            If you have already measured circle you can take the points out of it as a Construction Points (see picture below):
            (It is in v.2018, I'm not sure if before also)
            AUTO CIRCLE=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
                        THEO/<0,0,0>,<0,0,1>,50,0
                        ACTL/<0,0,0>,<0,0,1>,50,0
                        TARG/<0,0,0>,<0,0,1>
                        START ANG=0,END ANG=360
                        ANGLE VEC=<0,0,1>
                        DIRECTION=CCW
                        SHOW FEATURE PARAMETERS=NO
                        SHOW CONTACT PARAMETERS=YES
                          NUMHITS=14,DEPTH=5,PITCH=0
                          SAMPLE METHOD=SAMPLE_HITS
                          SAMPLE HITS=0,SPACER=0
                          AVOIDANCE MOVE=BOTH,DISTANCE=10
                        SHOW HITS=NO
            P1         =FEAT/POINT,CARTESIAN,NO
                        THEO/<5.563,24.3732,5>,<0,0,1>
                        ACTL/<5.563,24.3732,5>,<0,0,1>
                        CONSTR/POINT,CAST,AUTO CIRCLE.HIT[4..4]
            P2         =FEAT/POINT,CARTESIAN,NO
                        THEO/<15.5872,19.5458,5>,<0,0,1>
                        ACTL/<15.5872,19.5458,5>,<0,0,1>
                        CONSTR/POINT,CAST,AUTO CIRCLE.HIT[3..3]
            P3         =FEAT/POINT,CARTESIAN,NO
                        THEO/<25,0,5>,<0,0,1>
                        ACTL/<25,0,5>,<0,0,1>
                        CONSTR/POINT,CAST,AUTO CIRCLE.HIT[1..1]
            P4         =FEAT/POINT,CARTESIAN,NO
                        THEO/<15.5872,-19.5458,5>,<0,0,1>
                        ACTL/<15.5872,-19.5458,5>,<0,0,1>
                        CONSTR/POINT,CAST,AUTO CIRCLE.HIT[13..13]
            amor patriae nostra lex
