Hello and thanks in advance. I recently moved my 3R chuck, but when I realigned to it I had to move all my points and all my moves in my program. I thought once I realigned the part everything else would move with it. Am I missing a step (or steps) or will I have to do this every time an alignment changes?
New Alignment and New Moves.
The alignment code is attached. The manual alignment started from a recalled 3R alignment.Attached Files
pro tip: you can just copy-and-paste the code into this forum. Type [c o d e] before it and [/c o d e] after it (without spaces) and it will look like this:
Code:If PC-DMIS IsRunning Then crash End If
If I'm reading this correctly, you had a working program (with clean nominals) and everything was fine. You then made a substantial change to the location of the first alignment and your nominals for everything after changed.
Do the changed nominals look like the original location but in the new alignment?
If so, are there variables or expressions in the nominals of your alignment features for the first alignment?
Hi Griffin, I'm not sure of the answer to your questions. What happened was I moved my 3R chuck. When I placed it back in a slightly different location, I ran the 3R alignment program I have, saved it and then recalled that alignment in my existing program. The iterative alignment ran fine and the part was found, but everything after that didn't align. I'm not sure if it was supposed to or not. If so, I'm not sure what step or steps I missed. Thanks.
by Loon4everHey all, so I'm having alignment troubles today, Whenever I get to the ABC portion of the alignments my Trihedron stops moving when I select the Datum...
01-22-2019, 01:31 PM -
by jmzelekI imagine that there is a setting somewhere that I cannot find but, I have written several programs and as of late, I have programs that, after it runs,...
10-09-2017, 07:48 AM -
by Slug DawsonHello. I've been scouring this program to find any issues and came across this alignment. My question is why wouldn't an alignment like this with multiple...
02-12-2010, 04:56 PM -
I have been trying to do an iteritive alignment and I keep getting an alignment error. I can see in the code that it levels to z, but both rotate and...
01-08-2013, 03:48 PM -
by CFisherI'm a part-time CMM jockey - and it's been a few years since class...
I've got an alignment established - now I want a new one...I plan...-
01-25-2011, 01:03 PM -
