Yes, and it worked perfectly!
My apologies, I was away since Friday, and just saw your reply this morning. I would have replied then but I ran into another minor quirk, where wrong tolerances were being used, but that was all me (Tolerance assigned depending on an OP# Variable). Got that bit fixed, and it seems to exactly what we needed! This is also encouraging me to delve deeper into the scripting/VB side of things...
My many thanks to you, AndersI!
Excel/CSV Output Using Only Dimensions That Are Actually Executed (and Set to Output)
Here's the script code, as currently running.
Code:Sub Main() Dim App As Object Set App = CreateObject("PCDLRN.Application") Dim Part As Object Set Part = App.ActivePartProgram Dim Cmds As Object Set Cmds = Part.Commands Dim Cmd As Object Dim DCmd As Object Dim DcmdID As Object Dim TField As Object Dim fs As Object Dim Out_path As Object Dim DimID As String Dim ReportDim As String Dim CheckDim As String Dim DimCallout As String Dim DimTXT As String Dim FileNumb As Integer Set Out_path = Part.GetVariableValue ("OUT_PATH") DimTXT = Out_path.StringValue & "_DIMS.CSV" FileNumb = FreeFile Open DimTXT For Output As #FileNumb For Each Cmd In Cmds ' Check command Type If Cmd.Type <> 1299 Then If Cmd.IsTraceField Then Set TField = Cmd.TraceFieldCommand Write #FileNumb, TField.Name, TField.Value End If End If Next Cmd Write #FileNumb, "ID", "Nominal", "Plus Tol", "Minus Tol", "Actual", "Out-of-Tol" For Each Cmd In Cmds If Cmd.Type <> 1299 Then If Cmd.IsDimension Then If Cmd.Type = DIMENSION_START_LOCATION Or Cmd.Type = DIMENSION_TRUE_START_POSITION Then Set DcmdID = Cmd.DimensionCommand DimID = DcmdID.ID ReportDim = Cmd.GetText(OUTPUT_TYPE, 0) End If If Cmd.Type <> DIMENSION_START_LOCATION And Cmd.Type <> DIMENSION_END_LOCATION And Cmd.Type <> DIMENSION_TRUE_START_POSITION And Cmd.Type <> DIMENSION_TRUE_END_POSITION Then Set DCmd = Cmd.DimensionCommand CheckDim = Cmd.GetText(OUTPUT_TYPE, 0) If CheckDim <> "" Then ReportDim = CheckDim End If If ReportDim = "BOTH" Or ReportDim = "REPORT" Then If DCmd.ID = "" Then If DCmd.AxisLetter <> "TP" Then Print #FileNumb, Chr(34), DimID & "." & DCmd.AxisLetter, Chr(34), ",", Round(DCmd.Nominal, 4), ",", DCmd.Plus, ",", DCmd.Minus, ",", Round(DCmd.Measured, 4), ",", Round(DCmd.OutTol, 4) Else Print #FileNumb, Chr(34), DimID & "." & DCmd.AxisLetter, Chr(34), ",", Round(DCmd.Nominal, 4), ",", DCmd.Plus, ",", DCmd.Minus, ",", Round(DCmd.Deviation, 4), ",", Round(DCmd.OutTol, 4) End If Else If DCmd.AxisLetter <> "TP" Then Print #FileNumb, Chr(34), DCmd.ID, Chr(34), ",", Round(DCmd.Nominal, 4), ",", DCmd.Plus, ",", DCmd.Minus, ",", Round(DCmd.Measured, 4), ",", Round(DCmd.OutTol, 4) Else Print #FileNumb, Chr(34), DCmd.ID, Chr(34), ",", Round(DCmd.Nominal, 4), ",", DCmd.Plus, ",", DCmd.Minus, ",", Round(DCmd.Deviation, 4), ",", Round(DCmd.OutTol, 4) End If End If 'Add Min/Max For Profile dimensions If Cmd.Type = 1118 Or Cmd.Type = 1105 Then Print #FileNumb, Chr(34), DCmd.ID & ".Max", Chr$(34), ",", Round(DCmd.Nominal, 4), ",", DCmd.Plus, ",", DCmd.Minus, ",", Round(DCmd.Max, 4), ",", Round(DCmd.OutTol, 4) Print #FileNumb, Chr(34), DCmd.ID & ".Min", Chr$(34), ",", Round(DCmd.Nominal, 4), ",", DCmd.Plus, ",", DCmd.Minus, ",", Round(DCmd.Min, 4), ",", Round(DCmd.OutTol, 4) End If End If End If End If 'Do GDT If Cmd.Type = 184 Then ReportDim = Cmd.GetText(OUTPUT_TYPE, 0) If ReportDim = "BOTH" Or ReportDim = "REPORT" Then DimCallout = Cmd.GetText(LINE1_CALLOUT, 1) If DimCallout <> "" Then Print #FileNumb, Chr(34), Cmd.GetText(ID, 0), Chr(34), ",", Round(Cmd.GetText(LINE1_NOMINAL, 1), 4), ",", Cmd.GetText(LINE1_PLUSTOL, 1), ",", Cmd.GetText(LINE1_MINUSTOL, 1), ",", Round(Cmd.GetText(LINE1_DEV, 1), 4), ",", Round(Cmd.GetText(LINE1_OUTTOL, 1), 4) End If Print #FileNumb, Chr(34), Cmd.GetText(ID, 0), Chr(34), ",", Round(Cmd.GetText(LINE2_NOMINAL, 1), 4), ",", Cmd.GetText(LINE2_PLUSTOL, 1), ",", Cmd.GetText(LINE2_MINUSTOL, 1), ",", Round(Cmd.GetText(LINE2_DEV, 1), 4), ",", Round(Cmd.GetText(LINE2_OUTTOL, 1), 4) End If End If End If Next Cmd Close #FileNum End Sub Function Round(Value, Dec) As Double Dim TmpVal As Long TmpVal = Value * (10 ^ Dec) Round = TmpVal / (10 ^ Dec) End Function
This gave me a CSV that only showed the stuff executed in that operation, for each OP. Unfortunately, it also doubled the PDF report (just reports everything twice, even though only executed once with output)
Originally posted by AndersI View PostIn theory you would only replace a line (in the script) looking more or less like
Code:Set DmisCommands = DmisPart.Commands
Code:Set DmisCommands = DmisPart.ExecutedCommands
Originally posted by Ego Murphy View Post
FYI this kinda belongs in the Code Samples sub-forum but I ain't no mod so let's do this.
But anyway, the formatting is not so important, as long as it is consistent. We are developing various applications that would utilize the CSV files, so as long as it came out the same way every time, and only supplied the data for things that were executed, it would be swell.
Which version are you referring to? I'm currently developing everything in 2011 MR1, as it our lowest common denominator version-wise. We are considering updating the SMA on the two CMM's that are limited to 2011 MR1, which would put them all at 2013 MR1, or better.
Without .ExecutedCommands your script will *definitely* have problems as soon as your program uses LOOP, SUBROUTINE, IF, etc. - anything repeating or conditioinally executing parts of the program is not reflected in .Commands, only in .ExecutedCommands.
As an alternative you can try adding a test for DmisCommand.Skipped at the same place where you test DmisCommand.OutputMode (NONE, STAT, PRINT, BOTH) to decide if it should be printed or not. I have not tested this approach (at least I don't remember testing it), I've only seen that the .Skipped field exists… It would still be problematic with LOOP and other repeating constructs.
- Likes 1
Originally posted by edrake View PostOur last Quality Manager whipped up a handy little script that outputs a CSV file of the measurement results for a part. Unfortunately, the programs he developed it around were fairly simple, and we now want to use this output on all parts.
He was able to build it so that it would ignore any dimension commands that had an output of 'NONE' (which PCD2EXCEL apparently does not?). My problem arises with other more complex programs, that measure/don't measure various features based on which Operation is being inspected/in-process vs final dimensions/optional Operator input.
For instance, for one part (Airfoil) there is a Dovetail/General Features inspection for Op 45 (Dovetail only), Op 65 (additional Root features), and Op 105 (Final Inspection including both). The way our script currently runs, whichever Operation is run, the PDF report has all of the proper dimensions for that Op, but the CSV output has them all in tandem, and the dimensions for the OPs that didn't actually run will often be out of tolerance (especially scanned features).
The main thing they are trying to use this for is to compile a report of part serial #'s that are in tolerance, and ready to ship to customer/outside services (but we are developing it into other uses). Having these unmeasured dimensions included is obviously putting a kink in efforts to use the CSV files to look for blueprint parts.
Is there another way to do this? I could swear CSV output was standard when I first used PC-DMIS about 20 years ago (took a break for about 13 years), why would they get rid of it? We are currently running 2011 MR1 (X4), 2013 MR1 (X3), and 2017 R2 (X1). Essentially, I just want to put out the same report that I'm printing to PDF in CSV/Excel format.
Any ideas? Thanks in advance!
The single driving reason behind scripting CSV output is to Format the CMM's output data so that it is extremely useful for SPC, charting, graphing, tracking, automated reporting, etc., etc. as opposed to PC-DMIS's standard PDF reports that are only useful for the rare humans who can read CMM reports.
There are two aspects to this formatting, and the first one is native to CSV/Excel: you get numerical text data in an electronic file that nearly anything can read.
The second one is the customization: rows, columns, headers, names, units, date-time stamps, you can arrange the data anyway you like.
For example, Minitab SPC software wants one part to be only three rows: headers, nominal, actuals. No problem for a CSV script.
If the first is more important than the second, PC-DMIS's Excel reporting function (under the File Printing in newer versions, not that ancient clunky PCD2EXCEL wizard) works quite well. You can even toggle it to write straight CSV instead of XLSX file extension, and just like the PDF Report if something didn't get executed it's not in the report.
It does lack the precise formatting that a CSV script has. If your current CSV script arranges the data just right for some other system to ingest, then you have to keep it and modify as needed - or even replace it with a completely different scripting approach in order to meet the need of "don't report skipped stuff" - which really is a topic for the Code Sample section.
Keep in mind this also: if precise formatting is required, it may be a better use of time to just use the PC-DMIS Excel printing and then write an Excel macro in a master spreadsheet to collect, collate, and auto-format the raw data from the printed Excel files. This would make it easy to have the bad data thrown out, IF Operation=65 then skip Dimension 42B etc.
I report with exce csv everytime, output depends on operation to measure selected, but you need to put dimension tolerancing together with measuring routine blocks.
if op10 go blockA (measure A, evaluate A),
if op20 go blockB (measure B, evaluate B), etc
another thing, in the excel output there is a switch for output options (both, report, stats, none, output all regardless of these.), isnt it ?
I personally handle that by altering the output based on a variable that controls which sections of the program that gets executed. But that depends on the design of the programs of course.
It may be tough to help without seeing the script. Could you share it, or is it considered proprietary?
by Alex B-shiftWe have a run of 25 parts, each of which have 27 dimensions that we check 100%. I have a looping program made for this job, but I'd really like to be...
02-20-2014, 06:21 PM -
by Belly UpHey fellow "Demons",
So I just started a new job, and they do their first articles by looking at a stack of reports and manually...-
03-31-2022, 02:59 PM -
by DaSaloThey stuck in a new feature in sp2. There is now an option in the print dialog to select "EXCEL output" in addition to PDF and RTF. This seems...
03-30-2014, 12:25 PM -
by josephday76We recently purchased the Mitutoyo MeasurLink inspection software. We are a custom molder with many different customers so the level of inspection is...
09-16-2014, 12:18 PM -
by DaSaloUsing 2016 SP10:
I have recently switched from using the old external PCD2EXCEL wizard to using the internal Excel output option in the print...-
11-27-2018, 07:40 PM -
