Hello, first post. I'm still a newb to CMM and hoping someone can help me out. I am trying to enter true position info for my report and I think I have my control frame correct with datums and control frame info as it is on the print. My problem is my report has measured and nominal results the same. I am sure I am leaving out a step. I attached a link to the post hoping someone can show me what I am leaving out. Basically what is the step after I fill out the control frame info. Thanks
True Position report info
Tags: None
Did you run the part? If not, the measured and nominals will be the same. In addition, you have all three axis' selected for the features. Is this correct to the print? I rarely see a three axis true position, however, believe it or not I have two parts I am working on that require a 3 axis TP. If you go into the Advanced tab, you can select which axis to report, adjust tolerances on the features being measured, and other reporting enhancements.
by csshaffer
I am trying to explain to one of our engineers the logic used in determining the true position and how it is printed out on the report....-
02-20-2013, 05:03 PM -
by acgarciaUsing 2019 R1. Created 2 separate true position dimensions and I want to show Y and Z axis however the report only shows 1 axis.
I tried...-
05-05-2022, 02:06 PM -
by Tho35Hello,
I am kind of new user with PCdmis 4.1 , so please help me how to measure the True Position in Highlight area in my drawing attached,...-
12-07-2007, 04:38 PM -
by Rush2112i'm having an issue with the results between the TP and the actual deviations from nominal. the report will show a true position of whatever, but the...
08-17-2017, 09:30 AM -
by hunsibdWas wondering if all three axes are selected for a true position if PCDMIS will correctly compute the deviation for all three axes for the result? The...
08-31-2016, 09:23 AM -
