Flipping the X and Y to match print
  • Flipping the X and Y to match print
    Hello, I have a very big print with at least 100 dimensions being called out on it, now the problem i'm having is that after i imported the cad in and match my part set up to the cad, the xy are switched on the print on pcdmis y forward and back and x is side to side, and on the print its y side to side and x forward and back. How do i get pcdmis to match the print and the cad stay the same. I would really hate to go through every dimension and switch xy on the print. I hope i explain this well enough. Any help would be great
    When you set up your manual/DCC alignment, set it up so that it matches the print. That way when you do your reporting, everything will match. I hope this helps you.
    Darroll
    2018R2
    • MelissaM10
      MelissaM10 commented
      If i set up a manual alignment to match the print it flips the cad sideways.
    • Darrollh
      Darrollh commented
      The easiest way to do this is the way Andersi mentioned.
    Rotate your coordinate system 90 degrees?
    • Mike Ruff
      Mike Ruff commented
      +1. This will probably be the easiest way. Just insert an alignment right before the dimensions and rotate +90° (or -90° depending on the direction you want) about Z. You won't have to change anything with your setup
    • AndersI
      AndersI commented
      But save an extra copy of the program first, in case you happen to answer the "Alignment has changed" question wrong...
    • MelissaM10
      I will try this next thank you!
    Just some extra information: It is impossible to just 'flip' X and Y, as that would produce a left-handed coordinate system and PC-DMIS only does right-handed. This means that when you rotate XPLUS to become YPLUS, the rotated old YPLUS will point in the old XMINUS direction.
      Do you have a completely written program or are you starting to write the program? If you are just starting to write the program then I would (and do) transform the CAD to match how it is going to sit on the CMM.
      Last edited by A-machine-insp; 03-22-2019, 11:08 AM. Reason: I meant transform, not translate.
      Remembering my beautiful wife Taz who's life was taken from me on 6-13-2020.
        Transform the cad model by rotating it until your XYZ are where you want.
        • Mike Ruff
          Mike Ruff commented
          If the program is already written, you will need to rotate the whole program as well so it still lines up with the CAD. And if there are different angles used, those will also need to be changed to correlate with the new setup
