2017 r2 sp13
  • 2017 r2 sp13
    "Enhancements in progress - Don't stop"
    https://www.wilcoxassoc.com/public/P.../2017_R2/SP13/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve.../2017_R2/SP13/
    Release Notes - 2017 R2 SP13
    • PCD-138843 - Fixed an issue with poor-quality diagnostic bitmaps on Vision
    systems with high-resolution cameras.
    • PCD-150964 - Corrected an issue where, in some cases, laser auto features
    were not evaluated correctly when re-executed.
    • PCD-152892 - Fixed an issue where PC-DMIS stopped working when the
    frequency parameters for the CWS sensor were copied and pasted.
    • PCD-154463 - Fixed memory leaks that occurred at the end of a feature's
    execution when the DiagnosticsAutoExport registry entry was set to
    TRUE.
    • PCD-154699 - Fixed an issue that occurred when points were selected on the
    bottom layer of a triangle mesh model (JT, STL, Wavefront).
    • PCD-154896 - Fixed an issue where cylinder computation from b-spline
    surfaces had poor accuracy.
    • PCD-158032 - Fixed an issue with the TS/I++ PC-DMIS configuration where a
    dialog box with the wrist rotation appeared when it wasn't necessary (even
    without a wrist).
    • PCD-158772 - Fixed an issue where Feature Based Measurement (FBM) was
    not able to mark features correctly when assignment was used.
    • PCD-159042 - Fixed a potential crash when the Scan dialog box was opened.
    • PCD-160894 - Fixed an issue where Vision Auto Features, such as circles and
    lines with manual targets, had the crosshair shrink and disappear as the
    rotary angle went to 90 degrees.
    • PCD-160961 - Added the ability to immediately free diagnostic images. The
    DiagnosticsAutoFree registry entry in the PC-DMIS Settings Editor
    application enables you to immediately delete Vision diagnostic images in
    PC-DMIS memory after a feature is executed. If the registry entry is set to
    TRUE, the diagnostic image will not appear on the Vision Diagnostics tab in
    the Probe Toolbox. This setting can dramatically reduce the memory usage
    when the DiagnosticsAutoExport registry entry is set to TRUE.
    • Changes were made to improve the user experience based on feedback
    collected from recent releases.
    Thank you! I just uploaded! You must have a key to the PC-D vault?
    Darroll
    2018R2
    • JEFMAN
      JEFMAN commented
      Not yet !
    Is this an SP record?? 13??
      After seeing SP13 this was my first thought. "How many licks does it take to get to the Tootsie Roll center of a Tootsie Pop(How many SP's to fix PC-DMIS)? (crunch sound effect "CMM Crash") Narrator: The world may never know."
        Depends on the way of count...
        If you look at 2015 (release to SP5) and 2015.1 (release to SP10), you could find 16 SP (considering 2015.1 release as a 2015 SP6)
