How do you find the length of my chamfer
  • How do you find the length of my chamfer
    I am trying to find the distance of a chamfer. I have a cylinder and a cone but I have been unable to properly construct all this so that I can find out the distance or length of my chamfer.
    Are you measuring from the CAD?
    Darroll
    2018R2
      yup
        2018r1
          Create an intersect circle between the Chamfer and the Cylinder. Use this for location. I assume the other end would be a plane or something
            What IJ just wrote. I was going to go another route but you guys no better than I.
            Darroll
            2018R2
              You can measure a line on each of the 3 surfaces at the same X location. Then construct intersection points and dimension the distances.
              7107 Global Classic TP20
              2019R1 SP1 CAD++
              • InspectorJester
                InspectorJester commented
                It took me a second to understand this, but it does make sense;
                Take a line on the "top" of the cylinder
                Take a line on the face of the cylinder
                Take a line perpendicular to the chamfer
                Use two Intersect points (Top & Chamfer, Chamfer & Face) and dimension distance.
                I can't find anything wrong with that, technically...
              • RIDER
                RIDER commented
                Exactly! Thank you for clarifying InspectorJestor. With the 3 intersection points you are essentially creating your triangle so you can dimension each distance and angle of all legs involved.
              OK thanks I will try this and see if it works.
                What are you looking for, A or B ?
                For A : what InspectorJester said
                For B : construct another circle between cone and plane
                ASSIGN/B=SQRT(A^2+(CIRC2.R-CIRC1.R)^2), assuming that the circles are concentrics....
