Big Red Dot Sphere Autofeatures
    Originally posted by [email protected] View Post
    Yes that makes it smaller, thanks! Apparently when it's set to 0 it is appearing as .105. Multiple programs too...and I tried restarting...funny glitch...
    I think if you set it to ZERO, it uses the value in the OPENGL settings.
  • KIRBSTER269
  • lfrey@marox.com
    Originally posted by RIDER View Post
    First time I've ever seen that! Does anything change if you set your Pt. Size to 0.01 instead of 0?
  • louisd
    It looks like your features and probe are tiny, and the red dot is more 'normal' size (2mm I believe is default for displaying points).
    Go to Edit -> Graphic Display Window -> then "Display symbols"
    Within there, you will be able to adjust the diameter of your points.
  • KIRBSTER269
    Click your Void Detection button off. See if that helps
  • RIDER
  • lfrey@marox.com
    started a topic Big Red Dot Sphere Autofeatures
    I don't know what I did to turn this on. How do I get rid of it?
