I'm using 3.7mr3, PH10T, TP20, std force module. I have a 1mm probe with a 41mm length. (carbide shaft) When I built the probe file I used a 20mm ext. plus 1x20 probe. When I calibrate I noticed the probe dia. is about .0024 inch (I work in inches) undersize. My std dev. is fine. I attribute the difference to some flex in the probe due to the length. Does the fact that I can't build the probe length at exactly 41 mm have any bearing on this? Any thoughts on this are appreciated.
Thank You,
John
Thank You,
John
