During a programme,if the point you are measuring is out of position to the extent that you need to adjust the TARGET X,Y or Z to enable the part to be measured,why do you then have to go back to the start of the programme because if you do a partial execution you only recieve the data from that point onwards.is there away of adjusting the target or proceding without changing the target to allow you to aquired all the data from the programme.
Restart programme
Originally posted by Big Jeffers View PostDuring a programme,if the point you are measuring is out of position to the extent that you need to adjust the TARGET X,Y or Z to enable the part to be measured,why do you then have to go back to the start of the programme because if you do a partial execution you only recieve the data from that point onwards.is there away of adjusting the target or proceding without changing the target to allow you to aquired all the data from the programme.
When you get the error, stopping the machine because the feature is too far away from nominal, simply hit ALT-X to go into manual mode and manually measure the feature (Probably a hole or a slot, right?). When you are done taking all the hits, Pcdmis will then prompt you if you want to update the targets with the actuals, tell it YES, then it will sit and wait for you to hit ALT-Z and it will go back into DCC mode and continue the program.sigpic
Originally posted by Matthew D. Hoedeman View PostHere is a way around that:
When you get the error, stopping the machine because the feature is too far away from nominal, simply hit ALT-X to go into manual mode and manually measure the feature (Probably a hole or a slot, right?). When you are done taking all the hits, Pcdmis will then prompt you if you want to update the targets with the actuals, tell it YES, then it will sit and wait for you to hit ALT-Z and it will go back into DCC mode and continue the program.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
If You Use The Little Typewriter "print" Key You'll Get All Your Data EVEN AFTER A RESTARTLast edited by BOB PARSONS; 04-20-2007, 05:31 PM.GLOBAL FX 12-15-10
3.7MR3, XP/SP2
by XlarXlarI keep getting the error: "Hit target is out of detection range for feature ___"
This is when I am in manual mode and trying...-
Channel: PC-DMIS Vision
02-11-2015, 10:29 AM -
I have a program that measures the width of the keyway slots. I basically have a point taken on the inside of both sides. At times the slots are machine...
04-19-2007, 04:40 PM -
by djone368why does the target keep changing when you check a feature using auto feature?
shouldnt the target always be the same as the nominals?-
12-22-2007, 01:35 PM -
by TLCATLately, while in manual mode, the vision measurement tool is not appearing. You are asked to "align hit target" with your feature, but there...
03-04-2016, 03:36 PM -
How can one check some features on the CAD and have them kick out in the report while not checking the part.
10-21-2008, 01:34 PM -
