File I/O, Write Block, Carriage Return and Line Feed syntax?
  • File I/O, Write Block, Carriage Return and Line Feed syntax?
    I would like to know what the syntax is for a Carriage Return and Line Feed within the PCDMIS WriteBlock command?
    for example in Visual Basic its "vbCrLf"
    Mr. Comment
    SCIROCCO-NT 13-20-10
    you could try "\r\n" where
    \r - carriage return
    \n - line feed.
    I have not tried this myself so it is just a guess.
      I want to say that it is embeded to do it every time. All write operations (write and append) add a carriage return and line feed. If it is your desire to avoid it I can offer nothing. If it is your desire to add it then a blank write line will add a carriage return and line feed.
      FILE/WRITELINE,FPTR,
      Will write a carriage return and line feed only.
      Not ssure what your need is.
        WELCOME BACK CRAIGER!
        Did you come back only because the "fun pc-dmis site" is down?
        PCDMIS 2012
        Windows Office XP
          Haven't been on either actually. I stopped over there last week to see what the scoop was on the party. Been taking a break instead of making a complete *** of myself.
            What Ranger said!!!!!!! Get to say hello before the 12:30 (beer thirsty) bell sounds. Have a good Weekend dude
            sigpicRegards,
            Donald Henger
            B&S Micro Excel Pfx
            3.5mr2 & 3.7mr3
            PHH10MQ, TP20 & TP2
            Country Rocks,But Bluegrass RULES!!!
              Well, WELCOME BACK!
              We all (I think all of us) missed you!
              Henger, you finally changed avatars! The other one wasn't nearly as annoying though...
              PCDMIS 2012
              Windows Office XP
                Thanks for the suggestion. Unfortunately it just enters those switches as text.
                Mr. Comment
                  Writeline does add a Carriage Return and Line feed.
                  Write Block does not.
                  I want to write out a very large array of variables in one command instead of many, in the hopes that it will Execute much faster.
                  Maybe Im just stuck.
                  Mr. Comment
                    That stinks. I did not know that write block did that.
                    I know it is not the best solution but you could pass it to a script that will write it for you. Then you'll have a script acting as a broker of sorts which is not ideal. Ideally you could do it with PCDMIS. I'm afraid I have nothing else to offer. Who knows maybe bitsandmore will show up. He has solutions to some off the wall stuff.
                      OK - I think this will do it:
                      "1" + CHR(10)
                      will write a 1 followed by a line feed which should terminate the line of a text based file. So where you want to put a linefeed add a CHR(10) to the text.
                        "1" + CHR(10)
                        Nice, that just worked for me. I had an after thought. If you are using a bunch of variables and (I don't know how exactly you are doing this so it might not be doable) you could assign your variable in a loop and use writeline. That would cut down on code and line feed at the same time. Like I said not knowing how you are doing it that might just end up being cumbersome. Glad to see it can be done the way you wanted it though.
                        Craig
                          "1" + CHR(10)
                          Did that add an "implied" Carriage return? Or did the line just drop down directly under where it was entered at?
                            for a text file this will actually write a CR & LF.
                              Thanks SABarber,
                              That works.
                              Hopefully that will cut down on my execution time too.
                              Got to put that one in my notes.
                              Mr. Comment
