Pulling meas value into variable FCF problem!
  • Pulling meas value into variable FCF problem!
    Morning all,
    Does anyone know the syntax for pulling the measured variable from within an FCF dimension?
    For example (shown in attachment) if I want to pull a measured value for line 2 of a 4 dimension FCF what would be the code to point at that line?
    I have tried:
    ASSIGN/DIM3=FCFLOC1[2].MEAS
    ASSIGN/DIM3=FCFLOC1.line2.MEAS
    ASSIGN/DIM3=FCFLOC1[line2].MEAS
    and every other combination of this I can think of, and I can't find anything relevant searching the help file.
    Thanks in advance.
    Clearance is clearance.
    https://www.pcdmisforum.com/forum/pc...iple-features=
    • JackMido
      JackMido commented
      Cheers mate that is exactly what I needed! I fed the text values into a generic feature and exported the dimension from that. Thanks for your help pal.
    With the great stuff of SABarber and dph51, this is how I understand the way to make it works :
    1- create the fcf and update the report
    2- right click on the report, and look the pop-up text (line2..., summary...)
    3- seach in the data list the right line (ie line2.meas=688, summary.meas=692...
    ASSIGN/V1=GETCOMMAND(184,"UP",1)
    ASSIGN/V2=GETTEXT(688,1,V1) for the first value
    ASSIGN/V3=GETTEXT(692,8,V1) for the 8th line
    or directly
    ASSIGN/V2=GETTEXT(688,1,{FCFLOC1})
    Right click in the help file / available data allows printing them
