A couple of questions about true position call outs for datums.
1) I have a 4 Way "B" Datum hole. This hole resides on the primary Datum "A" surface. I have a diametrical true position call out of .1 of the hole to Datum "A" on the drawing. Is this feasible? If so how would it be possible to calculate TP of the hole to Datum "A"?
2) The same drawing has a call out for the 2 Way slot Datum "C" which also resides on the Datum "A" plane. The call out is .4 to "A" and "B" at MMC. I am confused as to why you would ask for TP when the feature itself has been used to rotate the alignment and set to nominal? What are you checking it to A/B since the alignment has not been established until rotating to "C"? Is the intent that you are verifying alignment by calling this out?
Sorry if confusing, I really appreciate any help here!
