I have little to no experience using true position. The concept I need to grasp is this. Does the part alignment datums have to be the same as the datums specified in the feature control frame or can these be defined in the dimensioning window. I have a print with several true position callouts using different datums. Must I do a new part alignment to each call out prior to creating the dimension?
Also can I do a true position of a feature set?
Thanks to all
Thanks to all
