Offline programming question??
  • Offline programming question??
    I am using PCDMIS 2017 R2. Sometime back when I first received the offline license and wrote programs I could see a virtual probe moving as the points where being take (running the program). Right now I can no longer see the probe at all and would like to know how to turn this feature back on; all help is most appreciated, thanks.
    F9 your loadprobe line and make sure all the components of the build are visible.
    • qcfire65
      qcfire65 commented
      Didn't think to look at this; thanks because they were all turned off.
    • A-machine-insp
      A-machine-insp commented
      Did that fix it?
    • qcfire65
      qcfire65 commented
      Problem is fixed.......
    In F5 setup General tab there is a box for Animate probe during Program Mode. Make sure that is checked.
    You can also load a virtual CMM. Put the cursor on the end of the Loadprobe command line. Then from the menu, Insert | Hardware Definition | Machine. Select a machine similar to yours and click Apply. This will put code into the program for a machine. If you just want the probe head drop down the menu and select No Machine. This will still show the head but no machine will be there. I use this when offline programming a lot.
    PC-DMIS 2016.0 SP8
    Jeff
      PROBE READOUT SET, turn on SHOW CURRENT POSITION OF PROBE
        If all else checks out and still nothing... put a LOADMACHINE command in your project and hide the virtual machine. That should keep your probe visible 100% of the time.
        PcDmis 2015.1 SP10 CAD++
        Global 7-10-7 DC800S
          Deja vu.
          PC-DMIS 2016.0 SP8
          Jeff
          • Kp61dude!
            Kp61dude! commented
            Could you keep your posts short and sweet so I won't miss anything when I skim read thru them next time?!!!! Geez some people these days...
            bahaha I never learn!
          I thought about putting the two different suggestions in two different comments, but I thought separating them with a space would be enough. I'll try to do better next time.
          PC-DMIS 2016.0 SP8
          Jeff
