True Position Help Datums not perp/parr
  • True Position Help Datums not perp/parr
    Hello all
    I'm trying to dimension this lovely part and I am running into something I thought might become an issue. This part has 5 Datums called out, A, B, C, D, and E. A is perpendicular to B but share the same Z vector, C is neither parallel or Perpendicular to A or B. C is perpendicular to D and E.
    So first this meant that I had to fudge my alignment to get it to work(A3), so a critique there would be nice. The issue is that the engineer wants the datum D hole called out to [C][B(M)][A], which PCDMIS keeps kicking back because "Secondary is neither parallel nor perpendicular to primary, so tertiary is not allowed.".
    ALIGNMENT/LEVEL,ZPLUS,DCC_PLN_1
    ALIGNMENT/ROTATE,XPLUS,TO,DCC_CYL_1,ABOUT,ZPLUS
    ALIGNMENT/TRANS,XAXIS,DCC_CIR_1
    ALIGNMENT/TRANS,YAXIS,DCC_CIR_1
    ALIGNMENT/TRANS,ZAXIS,DCC_PLN_1
    ALIGNMENT/END
    A3 =ALIGNMENT/START,RECALL:A2,LIST=YES
    ALIGNMENT/LEVEL,ZMINUS,DCC_PLN_A
    ALIGNMENT/ROTATE,ZPLUS,TO,DCC_CIR_B,ABOUT,XPLUS <---- Fudged part of alignment
    ALIGNMENT/TRANS,ZAXIS,DCC_PLN_A
    ALIGNMENT/TRANS,XAXIS,DCC_CIR_B
    ALIGNMENT/TRANS,YAXIS,DCC_CIR_B
    ALIGNMENT/END
    So how would you guys go about dimensioning this?
    Alignment:
    Level axis is C
    Rotation is to the B cylinder axis line, about C
    Origin X/Y to C
    Origin Z to axis/plane intersect of C to A.
    measure your D hole
    output TP relative to current alignment
    Well, unless there's basic dimensions that guide you otherwise.
    • louisd
      louisd commented
      I guess I misinterpreted the napkin. Thought the part components were cylindrical.
    • Loon4ever
      Loon4ever commented
      They are, only the top section that's at an angle isn't cylindrical. Boeing Part otherwise id just post the print.
    Maybe...
    Create a symmetry plane of C.
    Intersect this plane with A.
    Define this constructed line as datum C.
    Align A, rotate to C, origin in A + B.
    Use datum order A, C, B(M) in the evaluation.
    PC-DMIS CAD++ 2o19 R1 SP11
      I would say you're not describing the problem as it should... (it's not a criticism, just a way for me to translate my thoughts in english )
      In this case CBA, C is a midplane, B is a circle and A a point.
      There should have some boxed dimensions between the plane A and D and between B and D.
      In V2019, this case sould be treaed as it should, but in previous version, I think you have to change datums like A1 when A is a primary and A2 when it's a secondary (line) and A3 when it's a point .
      If you want to level on A, then you have to rotate on C.
      Just my thoughts...
        Nothing during 3 hours, and 3 replies during 3 mn !!!!!
        • vpt.se
          vpt.se commented
          The ketchup effect...
        Yeah sadly no basic dimensions with this part, however you guys are awesome and I'll start playing around with your suggestions...as soon as I reprogram everything I just lost because I forgot to save often.
        • louisd
          louisd commented
          do yourself a solid and start saving draft iterations. instead of just ctl+s do a file-Save as, then save each one as something like D1, D2, D3 at the end. Make comments to yourself on a notepad what you changed with each draft rev, and you can go back and redo things as often as you'd like.
        What ever you come up with, double check that alignment by RECALLING startup instead of a previous alignment. This will tell you 100% if all 6 DOF are locked down. When you are satisfied You can switch that recall back to your main alignment.
        • Loon4ever
          Loon4ever commented
          Yep, still had a rotational issue. Thanks for the tip!
