Hey all, so I'm having alignment troubles today, Whenever I get to the ABC portion of the alignments my Trihedron stops moving when I select the Datum Features.
I'll attach a little picture that hopefully gives you an idea of what I'm dealing with.
So what I currently have is a Manual Alignment, followed by a DCC alignment(using different features than the manual), and an ABC alignment using Datums A, B, and C. When I get to the ABC alignment I am unable to get my origin into the correct spot. If I use my non-datum features the origin moves around fine but even if I let PCDMIS "AUTO-SET ORIGIN" The code is correct as far as I can tell, but the origin still won't move. I confirm that it hasn't moved by taking an auto point on datum A, and where it should display a Z of 0 it still displays the distance to the old origin.
ALIGNMENT/LEVEL,ZPLUS,MAN_PLN_1
ALIGNMENT/ROTATE,XPLUS,TO,MAN_PLN_2,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,MAN_CIR_1
ALIGNMENT/TRANS,YAXIS,MAN_CIR_1
ALIGNMENT/TRANS,ZAXIS,MAN_PLN_1
ALIGNMENT/END
ALIGNMENT/LEVEL,ZPLUS,DCC_CIR_1
ALIGNMENT/ROTATE,XPLUS,TO,DCC_CYL_1,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,DCC_CIR_1
ALIGNMENT/TRANS,YAXIS,DCC_CIR_1
ALIGNMENT/TRANS,ZAXIS,DCC_PLN_1
ALIGNMENT/END
Anyone see anything in my code or the way I'm doing this that might be the cause. and please let me know if there's any more code I can post to help.20190122_122224.jpg
Don't know why It keeps turning the Photo to that orientation but It should be pretty clear which way is up.
ALIGNMENT/END
ALIGNMENT/END
