I'm having an issue with hole diameter in a plastic injection part. The hole is out of round approx. 0.020" I've run a scan of the diameter and exported the results into an .iges file to evaluate it in CAD and that correlates well with the roundness calculation from the dimensioning menu. Another way I have evaluated the diameter is to take 8 hits individual hits inside the diameter and created 4 distances. However, for the part program report that goes out to the customer, I am reporting out a Diameter, based on an auto circle (2.5 dia hole - 32 hits). How is this diameter calculated in an auto circle check? I assume it is an average of the 32 hits. Also, what do you think is the best way to measure and report out the diameter of this circle based on the fact that it is out of round? The customer's preference is for a single dimension on the report. I am thinking the best solution might be to report out the largest diameter using a distance check from 2 opposite points (the wider dimension is always in the same direction) and then report out the roundness using the auto circle feature. Comments or suggestions?
Circle Diameters
Originally posted by gcunniff View PostI'm having an issue with hole diameter in a plastic injection part. The hole is out of round approx. 0.020" I've run a scan of the diameter and exported the results into an .iges file to evaluate it in CAD and that correlates well with the roundness calculation from the dimensioning menu. Another way I have evaluated the diameter is to take 8 hits individual hits inside the diameter and created 4 distances. However, for the part program report that goes out to the customer, I am reporting out a Diameter, based on an auto circle (2.5 dia hole - 32 hits). How is this diameter calculated in an auto circle check? I assume it is an average of the 32 hits. Also, what do you think is the best way to measure and report out the diameter of this circle based on the fact that it is out of round? The customer's preference is for a single dimension on the report. I am thinking the best solution might be to report out the largest diameter using a distance check from 2 opposite points (the wider dimension is always in the same direction) and then report out the roundness using the auto circle feature. Comments or suggestions?sigpic
You can select the following for circle diameters.
Least Squares - The way I understand it it is the average dia.
Max. Inscribed - The biggest pin that will fit in a hole.
Min Circumscribed - The smallest ring that will fit around a stud.
I'd report max. inscribed as it sounds to me as if you have a hole and then dim. the roundness too.
Originally posted by Matthew D. Hoedeman View PostThere are several ways to ahve Pcdmis calculate the diameter of the tip, and they are in the AUTO-FEATURES CIRCLE menu. MAX-inscribed will give you the size of the biggest round pin that can go through the hole, which would probably be the best.
Originally posted by gcunniff View PostThis forum is like the Hoedeman hotline.
The problem with the gage pin method is that I don't have a 2.5" gage pin.sigpic
Originally posted by Goodluck View PostYou can select the following for circle diameters.
Originally posted by Matthew D. Hoedeman View PostOooohhh, and what sort of thing is THAT?!?!?!
Originally posted by Matthew D. Hoedeman View PostOooohhh, and what sort of thing is THAT?!?!?!When in doubt, post code. A second set of eyes might see something you missed.
by ricksterCan anyone tell me why I get a larger diameter measurement with the cmm than with a pin gage?
11-21-2008, 05:34 PM -
Okay Friends....The part is a simple 6x6 inch square of material 1/2 inch thick. There is a 4 inch diameter bore centered in the middle of the part. I...
05-01-2008, 12:10 PM -
by dtmtimI know this has been covered before but I can't seem to find it.
Using auto feature circle. The CMM data never correlates with a gage...-
02-10-2015, 05:03 PM -
by scannerHi everyone,
Beginner needs some help here. I am checking an inside Dia. at 2 different heights where a bearing seats. I have scanned...-
10-12-2007, 03:29 PM -
by markybarky10So I'm trying to measure a .250 +/-.001 auto cirlce, I'm taking 7 hits, the hole reports good but when I use dial bore the hole seems to be out of round...
03-03-2017, 12:05 PM -
