using pc-dmis 3.7 what,s the correct way to check angles, line to line or plane to plane, by useing the angularity or angle features in the dimension box FLA BILL
angles
Well, that depends on what you need to report. If you need to report the angle, make sure you are in the correct workplane, use 2D angle between, select the two features and click create. If you have a FCF specifying angularity, (you have my sympathy), use angularity, select the two features then click create. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Originally posted by cristian anabalon View Postusing pc-dmis 3.7 what,s the correct way to check angles, line to line or plane to plane, by useing the angularity or angle features in the dimension box FLA BILL
Anything further please ask.sigpic
Originally posted by John Kingston View PostThere are multiple ways, you just have to try. Trial and error works well. Wes is leading you in the right direction. His angularity sympathy comes from me too.sigpic
PCDMIS 2012
Windows Office XP
Hello all!
I have a cylindrical part mounted on a rotary table.
The print calls out 4 different angles on 4 subsequent sets of notches (each...-
09-01-2017, 11:49 AM -
by DeWain HodgeHow can I get PCD to report an 327° angle instead of -33°?
10-01-2010, 09:05 AM -
by Nada_Inc
So I'm trying to dimension this angle and I'm having no luck, in fact when dimensioning angles I pretty much have no luck....
02-28-2013, 12:25 PM -
by Curty_82Hello, I just went from 3.7 to 2009 MR1 and it wont let me do the complement angle any more.. How do I get pc dmis to report the old way so I can get...
04-23-2010, 01:14 PM -
by RideslowHow do I get the angle between 2 planes? One of them is nice and flat, the other one is pretty twisted. As am I right now......Do I have to construct...
03-29-2009, 05:34 PM -
