Assign Editbox value to variable - Form Editor
  • Assign Editbox value to variable - Form Editor
    Hi All,
    I am using the Form Editor for the first time. Right now I am trying to make a GUI where the operator should be able to write a value for a diameter in an EditBox. The diameter value should then be used within an Auto Feature Circle.
    I searched this forum, but I only found the opposite way: Assigning a value to a TextBox, or EditBox.
    Hope someone can help.
    Thanks
    Maybe you should use an inputbox ?
    Reading this could help you, even if it's a little old...
    ftp://ftp.wilcoxassoc.com/docs/pcdba...dbasic_pdf.zip
      Thanks JEFMAN,
      i'll definitely consider this - but I would really like to use the form editor.
        I found the answer: I forgot to put =variable("V1") in the EditBox text property.
