Point Names
  • Point Names
    Is it possible to create point names with upper and lower case letters - or will PC_DMIS always convert the lower case to upper case after typing? Thanks in advance.
    2017 R2 its not going to let me use lower case. GO BOLD OR GO HOME is the moral of the story !!
    • vlmitkov
      vlmitkov commented
      Dont wanna be a dick but... "GO CAPITAL OR GO HOME" ***
    I think (and I may be wrong here) but if you copy from notepad you can get lower and upper case, however I think when you reopen it will convert them all back to uppercase.
      ASSIGN/V1="Circle1"
      V1         =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                  THEO/<-11.5,5,8>,<0,0,1>,7
                  ACTL/<-11.5,5,8>,<0,0,1>,7
                  TARG/<-11.5,5,8>,<0,0,1>
                  START ANG=0,END ANG=360
                  ANGLE VEC=<1,0,0>
                  DIRECTION=CCW
                  SHOW FEATURE PARAMETERS=NO
                  SHOW CONTACT PARAMETERS=NO
      DIM LOC1= LOCATION OF CIRCLE CIRCLE1  UNITS=MM ,$
      GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  HALF ANGLE=NO
      AX    NOMINAL       +TOL       -TOL       MEAS        DEV     OUTTOL
      D        7.000      0.051      0.051      7.000      0.000      0.000 ---#----
      END OF DIMENSION LOC1
      Doesn't look like you can.
