Intersection of a Cone and a Line
  • Intersection of a Cone and a Line
    Hello!
    Running PC-DMIS 2018R2
    I have a part.
    Looks kind of like that.
    I need to find the point where the land [ | ] , who's Y-point I determine with a line, meets the cone.
    I draw an Auto Cone on the two slashes, and a line where the | character is.
    I need to find the corner, so for the "top half" of my awesome text drawing, from the top-left of the slash to the bottom of the |.
    Would a constructed intersect point do the job? Would I need to create a line instead?
    I need to find where the cone meets the land.
    I'll post actual drawings and schtuff, but I need to head out to lunch haha!
    Instead of an auto cone, couldn't you just do a couple of vector points, create a line, and do a line-to-line intersection around the part?
    I am hoping I understood your dilemma correctly. The awesomeness of the drawing should make it easy.....
      I think you need to use a pierce point, and not intersect one.
      Then, the result will depend on the direction of both cone and line (4 cases !), so you could have to create reverse features.
      • InspectorJester
        InspectorJester commented
        Would the pierce point be at the "top" of the cone or the center? I am looking to create a point on top, where, if the cone angle were to continue indefinitely, it would intersect with a point at the line's location, not necessarily intersecting with the line itself.
        I may need to use a plane
      I would love to post an image, but the 'ol usergroup quota has gotten me.
      | <---- LAND
      | <--- CORNER
      .........\ <--- CONE
      Last edited by InspectorJester; 01-09-2019, 01:26 PM. Reason: Forum doesn't like spaces
        I can't picture it.
          Something like this ?
          Maybe you could try to create a generic cone with the right angle, the same vertex than measured cone and the opposite direction.
          • InspectorJester
            My cone is actually the projected cone.
            The line and the point are correct
          If I understand correctly them my solution would be.
          Measure the cone, measure a plane around the top face land, Construct a circle using the cone/plane, Create a generic point and use the radius of the circle for the dimension you require.
            Something like this?
            CON1       =FEAT/CONTACT/CONE/DEFAULT,CARTESIAN,IN
                        THEO/<0,0,0.5924>,<0,0,1>,60,0.342,0.9449
                        ACTL/<0,0,0.5924>,<0,0,1>,60,0.342,0.9449
                        TARG/<0,0,0.5924>,<0,0,1>
                        START ANG=0,END ANG=360
                        ANGLE VEC=<-1,0,0>
                        SHOW FEATURE PARAMETERS=NO
                        SHOW CONTACT PARAMETERS=YES
                          NUMHITS=3,NUMLEVELS=3,DEPTH=0,END OFFSET=0
                          SAMPLE METHOD=SAMPLE_HITS
                          SAMPLE HITS=0,SPACER=0
                          AVOIDANCE MOVE=NO,DISTANCE=0.3937
                          ONERROR=NO,READ POS=NO
                        SHOW HITS=NO
            CIR1       =FEAT/CIRCLE,CARTESIAN,OUT,NO
                        THEO/<0,0,-0.2259>,<0,0,1>,0
                        ACTL/<0,0,-0.2259>,<0,0,1>,0
                        CONSTR/CIRCLE,CONE,CON1,DIAMETER,0
            F1         =GENERIC/CONE,DEPENDENT,CARTESIAN,OUT,$
                        NOM/XYZ,<CIR1.TX,CIR1.TY,CIR1.TZ>,$
                        MEAS/XYZ,<CIR1.X,CIR1.Y,CIR1.Z>,$
                        NOM/IJK,<0,0,-1>,$
                        MEAS/IJK,<CON1.I*-1,CON1.J*-1,CON1.K*-1>,$
                        DISTANCE/1,1,$
                        ANGLE/CON1.TA,CON1.A
            A1         =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                          ALIGNMENT/TRANS,XAXIS,CIR1
                          ALIGNMENT/TRANS,YAXIS,CIR1
                          ALIGNMENT/TRANS,ZAXIS,CIR1
                        ALIGNMENT/END
            CIR2       =FEAT/CIRCLE,CARTESIAN,OUT,NO
                        THEO/<0,0,0.5>,<0,0,1>,0.5774
                        ACTL/<0,0,0.5>,<0,0,1>,0.5774
                        CONSTR/CIRCLE,CONE,CON1,HEIGHT,0.5,REF_POINT = CONE_VERTEX,REF_VECTOR = CONE_VECTOR
            CIR3       =FEAT/CIRCLE,CARTESIAN,OUT,NO
                        THEO/<0,0,-0.5>,<0,0,-1>,0.5774
                        ACTL/<0,0,-0.5>,<0,0,-1>,0.5774
                        CONSTR/CIRCLE,CONE,F1,HEIGHT,0.5,REF_POINT = CONE_VERTEX,REF_VECTOR = CONE_VECTOR
            I included the circles to make sure I wa getting the conic correct, at the same height they should (and do) have the same diameter.
