Reporting Bug Details:
1. v4.2 (Build 3-22-07)
2. Use the "TextOnly.rpt" - (the default report)
3. Applys when using a Feature Set as a Datum. (Xact Measure GD&T, dimensions)
4. Occurs when you enable, "Use Text Mode Dimension Reporting"
Problem: When enabling "Use Text Mode Dimension Reporting" PCDMIS hangs at 99% and sets "Not Responding" in the task manager. The problem at the moment only seems to only occur if I use a Feature Set (Pattern of features) as a Datum in my FCF for my True Position dimensions.
The part program then also becomes permenatly bugged. Therefore all features in the edit window have to be copied and pasted into a new part program and you must not enable, "Use Text Mode Dimension Reporting".
I've also tried uninstalling and reinstalling the software.
Warning dont try to reproduce this in v4.1 or your program will be corrupted/deleted.
