Using Sub-programs
  • Using Sub-programs
    Hi Guys.
    There is a first time for everything, I'm told.
    I have never worked with sub-programming before, at least not with PC-DMIS.
    I have 4 versions of a part, and some of the geometry are on all 4 versions, but not at the same place.
    Other geometries are on 2 but not on the last 2 versions.
    The geometries are holes that looks like tulips.
    In the bottom, they have a cylinder, then a cone and finish of with the inside of a torus ( or donut).
    I was wondering, if it would be smarter for me to make the items in a sub-program, so that when the customer make changes, I'll only have to make my changes in the sub-program, instead of having them changed I all 4 programs.
    But, how di I do it?
    I mean, how do I get the dimension out of hole number 1 and keep the measured data from hole number 2?
    I have 4 holes looking the same, but on the report I'd like to have 4 different geometries measured and reported.
    Do I have to ASSIGN some variables every time the sub-program return some values, or....?
    If any one could post a screenshot of the concept, I'd be very happy.
    Or help me in any other way with a few tips of tricks, maybe even traps....
    Best regards
    Michael
    -- o --
    DEA Global - 09-15-08
    Renishaw PH10MQ w/ TP200 & SCR200-Rack
    PC-DMIS CAD Ver. 2017 R2 / PC-DMIS 2011 MR1
    I think I would do it by reading different text files containig theo values, and a case/end case at the start (look at DAN_M posts about it)
      You can dimension from a Sub with geometry in your part routine. You can also add geometry in the sub, to dimension geometry from sub in your part program is a bit tricky but doable.
      Dimensions in Sub, Geometry in part routine method.
      Program...
      PART NAME  : delete
      REV NUMBER :
      SER NUMBER :
      STATS COUNT : 1
      STARTUP    =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES
                  ALIGNMENT/END
                  MODE/MANUAL
                  LOADPROBE/LSPX1_2X40
      MAN_ALIGN  =GROUP/SHOWALLPARAMS=YES
      PLN1         =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE
                    THEO/<4.3256,0.4986,0>,<0,0,1>
                    ACTL/<4.3256,0.4986,0>,<0,0,1>
                    TARG/<4.3256,0.4986,0>,<0,0,1>
                    ANGLE VEC=<1,0,0>,SQUARE
                    SHOW FEATURE PARAMETERS=NO
                    SHOW CONTACT PARAMETERS=YES
                      NUMHITS=2,NUMROWS=2
                      SPACER=1.5
                      AVOIDANCE MOVE=NO,DISTANCE=0.3937
                    SHOW HITS=NO
      A1           =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                      ALIGNMENT/LEVEL,ZPLUS,PLN1
                      ALIGNMENT/TRANS,ZAXIS,PLN1
                    ALIGNMENT/END
      LIN1         =FEAT/CONTACT/LINE/DEFAULT,CARTESIAN,UNBOUNDED
                    THEO/<1.6132,0,0>,<1,0,0>,<0,-1,0>,<0,0,1>,5.5504
                    ACTL/<1.6132,0,0>,<1,0,0>,<0,-1,0>,<0,0,1>,5.5504
                    TARG/<1.6132,0,0>,<1,0,0>,<0,-1,0>,<0,0,1>
                      NUMHITS=3,DEPTH=0
                      SAMPLE METHOD=SAMPLE_HITS
                      SAMPLE HITS=3,SPACER=0,INDENT1=0,INDENT2=0
                    SHOW HITS=NO
      A2           =ALIGNMENT/START,RECALL:A1,LIST=YES
                      ALIGNMENT/ROTATE,XPLUS,TO,LIN1,ABOUT,ZPLUS
                      ALIGNMENT/TRANS,YAXIS,LIN1
                    ALIGNMENT/END
      PNT1         =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                    THEO/<0,0.4215,-1.0676>,<-1,0,0>
                    ACTL/<0,0.4215,-1.0676>,<-1,0,0>
                    TARG/<0,0.4215,-1.0676>,<-1,0,0>
                    SNAP=NO
                    SHOW HITS=NO
      A3           =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                      ALIGNMENT/TRANS,XAXIS,PNT1
                    ALIGNMENT/END
                  ENDGROUP/ID=MAN_ALIGN
                  CLEARP/ZPLUS,0.25,ZPLUS,0,OFF
                  MOVE/CLEARPLANE
      DCC_ALIGN  =GROUP/SHOWALLPARAMS=YES
                    Changing to DCC mode! Do not continue unless avoidance moves have been added.
                    MODE/DCC
      PLN1_DCC     =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE
                      NUMHITS=2,NUMROWS=2
                      SPACER=1.5
                    SHOW HITS=NO
      A3_DCC1      =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                      ALIGNMENT/LEVEL,ZPLUS,PLN1_DCC
                      ALIGNMENT/TRANS,ZAXIS,PLN1_DCC
                    ALIGNMENT/END
                    MOVE/CLEARPLANE
      LIN1_DCC     =FEAT/CONTACT/LINE/DEFAULT,CARTESIAN,UNBOUNDED
                      NUMHITS=3,DEPTH=0
                    SHOW HITS=NO
      A3_DCC2      =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                      ALIGNMENT/ROTATE,XPLUS,TO,LIN1_DCC,ABOUT,ZPLUS
                      ALIGNMENT/TRANS,YAXIS,LIN1_DCC
                    ALIGNMENT/END
                    MOVE/CLEARPLANE
      PNT1_DCC     =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                    SNAP=NO
                    SHOW HITS=NO
      A3_DCC3      =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                      ALIGNMENT/TRANS,XAXIS,PNT1_DCC
                    ALIGNMENT/END
                    MOVE/CLEARPLANE
                  ENDGROUP/ID=DCC_ALIGN
      CIR1       =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                  THEO/<3.6811,3.1693,0>,<0,0,1>,0.5906
                  ACTL/<3.6811,3.1693,0>,<0,0,1>,0.5906
                  TARG/<3.6811,3.1693,0>,<0,0,1>
                  START ANG=0,END ANG=360
                  ANGLE VEC=<1,0,0>
                  DIRECTION=CCW
                    NUMHITS=4,DEPTH=0.125,PITCH=0.0492
                    SAMPLE HITS=3,SPACER=0.065
                    AVOIDANCE MOVE=NO,DISTANCE=0.15
                  SHOW HITS=NO
                  MOVE/CLEARPLANE
      CIR2       =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                  THEO/<6.0827,3.1693,0>,<0,0,1>,0.5906
                  ACTL/<6.0827,3.1693,0>,<0,0,1>,0.5906
                  TARG/<6.0827,3.1693,0>,<0,0,1>
                  ANGLE VEC=<1,0,0>
                  DIRECTION=CCW
                  SHOW HITS=NO
                  MOVE/CLEARPLANE
      CIR3       =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                  THEO/<6.0827,0.7677,0>,<0,0,1>,0.5906
                  ACTL/<6.0827,0.7677,0>,<0,0,1>,0.5906
                  TARG/<6.0827,0.7677,0>,<0,0,1>
                  ANGLE VEC=<1,0,0>
                  DIRECTION=CCW
                  SHOW HITS=NO
                  MOVE/CLEARPLANE
      CIR4       =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                  THEO/<3.6811,0.7677,0>,<0,0,1>,0.5906
                  ACTL/<3.6811,0.7677,0>,<0,0,1>,0.5906
                  TARG/<3.6811,0.7677,0>,<0,0,1>
                  ANGLE VEC=<1,0,0>
                  DIRECTION=CCW
                  SHOW HITS=NO
                  MOVE/CLEARPLANE
      CS1        =CALLSUB/PART1_DIMS,C:\Users\Public\Documents\WAI\PC-DMIS\2015.1\Subroutines\Subroutine_Dimensions.PRG:{CIR1},{CIR2},{CIR3},{CIR3},,
      PcDmis 2015.1 SP10 CAD++
      Global 7-10-7 DC800S
        Subroutine
        PART NAME  : Subroutine_Dimensions
        REV NUMBER :
        SER NUMBER :
        STATS COUNT : 1
                    ALIGNMENT/END
                    MODE/MANUAL
                    GOTO/END
        FORREF1    =GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$
                    NOM/XYZ,<0,0,0>,$
                    MEAS/XYZ,<0,0,0>,$
                    NOM/IJK,<0,0,1>,$
                    MEAS/IJK,<0,0,1>,$
                    RADIUS/1,1
        PART#1     =GROUP/SHOWALLPARAMS=YES
                      SUBROUTINE/PART1_DIMS,
                          TCIR1 =  : ,
                          TCIR2 =  : ,
                          TCIR3 =  : ,
                          TCIR4 =  : ,
          DIM LOC1= LOCATION OF CIRCLE TCIR1  UNITS=IN ,$
          GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  HALF ANGLE=NO
          AX    NOMINAL       +TOL       -TOL       MEAS        DEV     OUTTOL
          X       0.0000     0.0100     0.0100     0.0000     0.0000     0.0000 ----#----
          Y       0.0000     0.0100     0.0100     0.0000     0.0000     0.0000 ----#----
          D       2.0000     0.0150     0.0150     2.0000     0.0000     0.0000 ----#----
          END OF DIMENSION LOC1
          DIM LOC2= LOCATION OF CIRCLE TCIR2  UNITS=IN ,$
          END OF DIMENSION LOC2
          DIM LOC3= LOCATION OF CIRCLE TCIR3  UNITS=IN ,$
          END OF DIMENSION LOC3
          DIM LOC4= LOCATION OF CIRCLE TCIR4  UNITS=IN ,$
          END OF DIMENSION LOC4
                      ENDSUB/
                    ENDGROUP/ID=PART#1
        END        =LABEL/
        notice I built a generic name "FORREF1" outside of sub "PART1_DIMS", I had to do that in order to create location dimensions. Those dimensions later got addressed to "TCIR1" thru "TCIR4". Otherwise your dimension will light up red as if there's an Error.
          Geometry in Subroutine, Dimensions in part routine method.
          Here's the tricky part I mentioned (well not so tricky just took me a long time to figure out).
          Part Routine:
          PART NAME  : delete
          REV NUMBER :
          SER NUMBER :
          STATS COUNT : 1
                      ALIGNMENT/END
                      MODE/MANUAL
                          NUMHITS=2,NUMROWS=2
                          SPACER=1.5
                        SHOW HITS=NO
                        ALIGNMENT/END
                          NUMHITS=3,DEPTH=0
                        SHOW HITS=NO
                        ALIGNMENT/END
                        SNAP=NO
                        SHOW HITS=NO
                        ALIGNMENT/END
                      MOVE/CLEARPLANE
                        MODE/DCC
                          NUMHITS=2,NUMROWS=2
                          SPACER=1.5
                        SHOW HITS=NO
                        ALIGNMENT/END
                        MOVE/CLEARPLANE
                          NUMHITS=3,DEPTH=0
                        SHOW HITS=NO
                        ALIGNMENT/END
                        MOVE/CLEARPLANE
                        SNAP=NO
                        SHOW HITS=NO
                        ALIGNMENT/END
                        MOVE/CLEARPLANE
          CS1        =CALLSUB/PART1_GEO,C:\Users\Public\Documents\WAI\PC-DMIS\2015.1\Subroutines\Subroutine_Dimensions.PRG:,,,,,
          DIM LOC1= LOCATION OF CIRCLE CS1:CIR1  UNITS=IN ,$
          X       3.6811     0.0100     0.0100     3.6811     0.0000     0.0000 ----#-----
          Y       3.1693     0.0100     0.0100     3.1693     0.0000     0.0000 ----#-----
          D       0.5906     0.0150     0.0150     0.5906     0.0000     0.0000 ----#-----
          DIM LOC2= LOCATION OF CIRCLE CS1:CIR2  UNITS=IN ,$
          X       6.0827     0.0100     0.0100     6.0827     0.0000     0.0000 ----#-----
          DIM LOC3= LOCATION OF CIRCLE CS1:CIR3  UNITS=IN ,$
          Y       0.7677     0.0100     0.0100     0.7677     0.0000     0.0000 ----#-----
          DIM LOC4= LOCATION OF CIRCLE CS1:CIR4  UNITS=IN ,$
            Subroutine:
            REV NUMBER :
            SER NUMBER :
            STATS COUNT : 1
                        ALIGNMENT/END
                        MODE/MANUAL
                        GOTO/END
                          SUBROUTINE/PART1_GEO,
                          ANGLE VEC=<1,0,0>
                          DIRECTION=CCW
                          SHOW HITS=NO
                          MOVE/CLEARPLANE
                          ANGLE VEC=<1,0,0>
                          DIRECTION=CCW
                          SHOW HITS=NO
                          MOVE/CLEARPLANE
                          ANGLE VEC=<1,0,0>
                          DIRECTION=CCW
                          SHOW HITS=NO
                          MOVE/CLEARPLANE
                          ANGLE VEC=<1,0,0>
                          DIRECTION=CCW
                          SHOW HITS=NO
                          MOVE/CLEARPLANE
                          ENDSUB/
                        ENDGROUP/ID=PART#1
            END        =LABEL/
              You can also combine geometry and dimensions in subroutine or have a separate sub call for geometry and call for dimensions all in one subroutine library.
              Dimensions and Geometry in Sub method.
              Part routine:
              PART NAME  : delete
              REV NUMBER :
              SER NUMBER :
              STATS COUNT : 1
                          ALIGNMENT/END
                          MODE/MANUAL
                              NUMHITS=2,NUMROWS=2
                              SPACER=1.5
                            SHOW HITS=NO
                            ALIGNMENT/END
                              NUMHITS=3,DEPTH=0
                            SHOW HITS=NO
                            ALIGNMENT/END
                            SNAP=NO
                            SHOW HITS=NO
                            ALIGNMENT/END
                          MOVE/CLEARPLANE
                            MODE/DCC
                              NUMHITS=2,NUMROWS=2
                              SPACER=1.5
                            SHOW HITS=NO
                            ALIGNMENT/END
                            MOVE/CLEARPLANE
                              NUMHITS=3,DEPTH=0
                            SHOW HITS=NO
                            ALIGNMENT/END
                            MOVE/CLEARPLANE
                            SNAP=NO
                            SHOW HITS=NO
                            ALIGNMENT/END
                            MOVE/CLEARPLANE
              CS2        =CALLSUB/PART1_DIMS,C:\Users\Public\Documents\WAI\PC-DMIS\2015.1\Subroutines\Subroutine_Dimensions.PRG:{CS1:CIR1},{CS1:CIR2},{CS1:CIR3},{CS1:CIR4},,,
                Subroutine:
                REV NUMBER :
                SER NUMBER :
                STATS COUNT : 1
                            ALIGNMENT/END
                            MODE/MANUAL
                            GOTO/END
                            NOM/XYZ,<0,0,0>,$
                            MEAS/XYZ,<0,0,0>,$
                            NOM/IJK,<0,0,1>,$
                            MEAS/IJK,<0,0,1>,$
                            RADIUS/1.5,1.5
                PART#1_GEO =GROUP/SHOWALLPARAMS=YES
                              ANGLE VEC=<1,0,0>
                              DIRECTION=CCW
                              SHOW HITS=NO
                              MOVE/CLEARPLANE
                              ANGLE VEC=<1,0,0>
                              DIRECTION=CCW
                              SHOW HITS=NO
                              MOVE/CLEARPLANE
                              ANGLE VEC=<1,0,0>
                              DIRECTION=CCW
                              SHOW HITS=NO
                              MOVE/CLEARPLANE
                              ANGLE VEC=<1,0,0>
                              DIRECTION=CCW
                              SHOW HITS=NO
                              MOVE/CLEARPLANE
                              ENDSUB/
                            ENDGROUP/ID=PART#1_GEO
                PART#1_DIMS=GROUP/SHOWALLPARAMS=YES
                                  TCIR1 =  : ,
                                  TCIR2 =  : ,
                                  TCIR3 =  : ,
                                  TCIR4 =  : ,
                  X       3.6811     0.0000     0.0000     3.6811     0.0000     0.0000 #--------
                  Y       3.1693     0.0000     0.0000     3.1693     0.0000     0.0000 #--------
                  Z       0.0000     0.0000     0.0000     0.0000     0.0000     0.0000 #--------
                  D       0.5906     0.0000     0.0000     0.5906     0.0000     0.0000 #--------
                  X       6.0827     0.0000     0.0000     6.0827     0.0000     0.0000 #--------
                  Y       0.7677     0.0000     0.0000     0.7677     0.0000     0.0000 #--------
                              ENDSUB/
                            ENDGROUP/ID=PART#1_DIMS
                END        =LABEL/
                There's no need to build "FORREF1" with this method as you can address your dimensions to existing geometry in sub just make sure to go back and change name of feature geometry to "TCIR1" thru "TCIR4".
                  Did this make sense to anyone?
                  Edit: I guess not haha...
                    Made sense to me but the parts we have here i will not need this. It looks like a great way to get the results that you need.
                    Time for the Trolls to leave.
                      Some how it makes sense, but You are still measuring 4 identical circles.
                      I was looking for a method on measuring one circle 4 times, or just 2 times.
                      Something like this:
                      PROGRAM =LABEL/
                      MODE/DCC
                      LOADPROBE/T1D2L40
                      TIP/T1A0B0, SHANKIJK=-0.174, 0.01, 0.985, ANGLE=-0.179
                      WORKPLANE/ZPLUS
                      CLEARP/ZPLUS,5,ZPLUS,5,OFF
                      MOVE/POINT,NORMAL,<-85,94,50>
                      MOVESPEED/ MEDIUM
                      THEO/<-85,94,20>,<0,0,1>
                      ACTL/<-85,94,20>,<0,0,1>
                      TARG/<-85,94,20>,<0,0,1>
                      SNAP=NO
                      AVOIDANCE MOVE=BOTH,DISTANCE=5
                      SHOW HITS=YES
                      HIT/BASIC,<-85,94,20>,<0,0,1>,<-85,94,20>
                      ENDMEAS/
                      PNT2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                      THEO/<-45,49,20>,<0,0,1>
                      ACTL/<-45,49,20>,<0,0,1>
                      TARG/<-45,49,20>,<0,0,1>
                      SNAP=NO
                      SHOW HITS=YES
                      HIT/BASIC,<-45,49,20>,<0,0,1>,<-45,49,20>
                      ENDMEAS/
                      PNT3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                      THEO/<-85,4,20>,<0,0,1>
                      ACTL/<-85,4,20>,<0,0,1>
                      TARG/<-85,4,20>,<0,0,1>
                      SNAP=NO
                      SHOW HITS=YES
                      HIT/BASIC,<-85,4,20>,<0,0,1>,<-85,4,20>
                      ENDMEAS/
                      PLN1 =FEAT/PLANE,CARTESIAN,OUTLINE,NO
                      THEO/<-71.667,49,20>,<0,0,1>
                      ACTL/<-71.667,49,20>,<0,0,1>
                      CONSTR/PLANE,BF,PNT1,PNT2,PNT3,,
                      OUTLIER_REMOVAL/OFF,3
                      FILTER/OFF,WAVELENGTH=0
                      A1 =ALIGNMENT/START,RECALL:A1_VICE,LIST=YES
                      ALIGNMENT/END
                      MOVE/POINT,NORMAL,<-30,4,5>
                      PNT4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                      THEO/<-40,4,-2>,<1,0,0>
                      ACTL/<-40,4,-2>,<1,0,0>
                      TARG/<-40,4,-2>,<1,0,0>
                      SNAP=NO
                      SHOW HITS=YES
                      HIT/BASIC,<-40,4,-2>,<1,0,0>,<-40,4,-2>
                      ENDMEAS/
                      PNT5 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                      THEO/<-40,94,-2>,<1,0,0>
                      ACTL/<-40,94,-2>,<1,0,0>
                      TARG/<-40,94,-2>,<1,0,0>
                      SNAP=NO
                      SHOW HITS=YES
                      HIT/BASIC,<-40,94,-2>,<1,0,0>,<-40,94,-2>
                      ENDMEAS/
                      LIN1 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
                      THEO/<-40,4,-2>,<0,1,0>
                      ACTL/<-40,4,-2>,<0,1,0>
                      CONSTR/LINE,BF,3D,PNT4,PNT5,,
                      ALIGNMENT/ROTATE,YPLUS,TO,LIN1,ABOUT,ZPLUS
                      ALIGNMENT/TRANS,XAXIS,LIN1
                      ALIGNMENT/END
                      MOVE/CLEARPLANE
                      MOVE/POINT,NORMAL,<-25,-55,5>
                      PNT6 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                      THEO/<-25,0,-2>,<0,-1,0>
                      ACTL/<-25,0,-2>,<0,-1,0>
                      TARG/<-25,0,-2>,<0,-1,0>
                      SNAP=NO
                      SHOW HITS=YES
                      HIT/BASIC,<-25,0,-2>,<0,-1,0>,<-25,0,-2>
                      ENDMEAS/
                      A_PART =ALIGNMENT/START,RECALL:A1_VICE,LIST=YES
                      ALIGNMENT/TRANS,YAXIS,PNT6
                      ALIGNMENT/END
                      MOVE/CLEARPLANE
                      MOVE/POINT,NORMAL,<-25,25,5>
                      CYL_D20_A =FEAT/CONTACT/CYLINDER/DEFAULT,CARTESIAN,IN,LEAST_SQR
                      THEO/<-25,25,-12.375>,<0,0,1>,15,12.625
                      ACTL/<-25,25,-12.375>,<0,0,1>,15,12.625
                      TARG/<-25,25,-12.375>,<0,0,1>
                      ANGLE VEC=<0,0,-1>
                      DIRECTION=CCW
                      NUMHITS=4,NUMLEVELS=2,DEPTH=2,END OFFSET=2,PITCH=0
                      SAMPLE HITS=0,SPACER=3
                      AVOIDANCE MOVE=NO,DISTANCE=3
                      FIND HOLE=NOCENTER,ONERROR=NO,READ POS=NO
                      SHOW HITS=YES
                      HIT/BASIC,<-17.5,25,-23>,<-1,0,0>,<-17.5,25,-23>
                      HIT/BASIC,<-25,32.5,-23>,<0,-1,0>,<-25,32.5,-23>
                      HIT/BASIC,<-32.5,25,-23>,<1,0,0>,<-32.5,25,-23>
                      HIT/BASIC,<-25,17.5,-23>,<0,1,0>,<-25,17.5,-23>
                      HIT/BASIC,<-25,17.5,-14.375>,<0,1,0>,<-25,17.5,-14.375>
                      HIT/BASIC,<-32.5,25,-14.375>,<1,0,0>,<-32.5,25,-14.375>
                      HIT/BASIC,<-25,32.5,-14.375>,<0,-1,0>,<-25,32.5,-14.375>
                      HIT/BASIC,<-17.5,25,-14.375>,<-1,0,0>,<-17.5,25,-14.375>
                      ENDMEAS/
                      CON_D30_A =FEAT/CONTACT/CONE/DEFAULT,CARTESIAN,IN
                      THEO/<-25,25,0>,<0,0,1>,44,-12.375,30
                      ACTL/<-25,25,0>,<0,0,1>,44,-12.375,30
                      TARG/<-25,25,0>,<0,0,1>
                      ANGLE VEC=<0,0,1>
                      AVOIDANCE MOVE=NO,DISTANCE=5
                      SHOW HITS=YES
                      HIT/BASIC,<-10.808,25,-2>,<-0.9271839,0,0.3746066>,<-10.808,25,-2>
                      HIT/BASIC,<-25,39.192,-2>,<0,-0.9271839,0.3746066>,<-25,39.192,-2>
                      HIT/BASIC,<-39.192,25,-2>,<0.9271839,0,0.3746066>,<-39.192,25,-2>
                      HIT/BASIC,<-25,10.808,-2>,<0,0.9271839,0.3746066>,<-25,10.808,-2>
                      HIT/BASIC,<-25,14.192,-10.375>,<0,0.9271839,0.3746066>,<-25,14.192,-10.375>
                      HIT/BASIC,<-35.808,25,-10.375>,<0.9271839,0,0.3746066>,<-35.808,25,-10.375>
                      HIT/BASIC,<-25,35.808,-10.375>,<0,-0.9271839,0.3746066>,<-25,35.808,-10.375>
                      HIT/BASIC,<-14.192,25,-10.375>,<-0.9271839,0,0.3746066>,<-14.192,25,-10.375>
                      ENDMEAS/
                      MOVE/CLEARPLANE
                      MOVE/POINT,NORMAL,<-25,75,5>
                      Here it repeats HOLE-2 and CONE-2
                      MOVE/CLEARPLANE
                      MOVESPEED/ FAST
                      MOVE/POINT,NORMAL,<-25,250,400>
                      The report would look like this
                      COMMENT/REPT,
                      ~~1 INFORMATION:
                      There are 2 cylinders (HOLE-1 & HOLE-2), and there are 2 cones (CONE-1 & CONE-2)
                      The cylinders are ø20 and goes from a depth of Z-20 to Z-12.375
                      The cones starts down in Z-12.375 and goes up to Z0
                      The diameter in Z-12.375 is ø20, and at Z0 the diameter is ø30, so the angle is 22°
                      COMMENT/REPT,
                      Position of HOLE-1.
                      DIM LOC1= LOCATION OF CYLINDER CYL_D20_A UNITS=MM ,$
                      X -25.000+0 0.500 -0.500 -25.000 0.000 0.000 -#--
                      Y 25.000+0 0.500 -0.500 25.000 0.000 0.000 -#--
                      D 15.000+0 0.500 -0.500 15.000 0.000 0.000 -#--
                      COMMENT/REPT,
                      Position of CONE-1.
                      DIM LOC2= LOCATION OF CONE CON_D30_A UNITS=MM ,$
                      D 30.000+0 0.500 -0.500 30.000 0.000 0.000 -#--
                      A 44.000+0 0.500 -0.500 44.000 0.000 0.000 -#--
                      L -12.375+0 0.500 -0.500 -12.375 0.000 0.000 -#--
                      And the same for HOLE-2 and CONE-2
                      But where the cylinder and cone are put in a sub-routine, and the values from them, are "transferred" back to the main program.
                      That was my issue.
                      How can I do that?
                      How do I "tell" the sub-routine the position of the features?
                      Do I have to "rename" the data from the subroutine when the features are measured?
                      Last but not least, how do I separate the data from the 2 sets of data.
                      Does that make sense?
                      Best regards
                      Michael
                      -- o --
                        Simple.
                        Throw your feature/s in your sub routine and from your part program call that sub as many times as you'd like. Now on the dimension side, you have to choose a method as there's many. I would personally go with example on post #5 "Geometry in Subroutine, Dimensions in part routine method."
                        Post your code within the appropriate tags, makes it easier to view it, like this:
                        PROGRAM =LABEL/
                        MODE/DCC
                        LOADPROBE/T1D2L40
                        WORKPLANE/ZPLUS
                        MOVESPEED/ MEDIUM
                        SNAP=NO
                        SHOW HITS=YES
                        ENDMEAS/
                        SNAP=NO
                        SHOW HITS=YES
                        ENDMEAS/
                        SNAP=NO
                        SHOW HITS=YES
                        ENDMEAS/
                        ALIGNMENT/END
                        SNAP=NO
                        SHOW HITS=YES
                        ENDMEAS/
                        SNAP=NO
                        SHOW HITS=YES
                        ENDMEAS/
                        ALIGNMENT/END
                        MOVE/CLEARPLANE
                        SNAP=NO
                        SHOW HITS=YES
                        ENDMEAS/
                        ALIGNMENT/END
                        MOVE/CLEARPLANE
                        Delete from here to....
                        ANGLE VEC=<0,0,-1>
                        DIRECTION=CCW
                        SHOW HITS=YES
                        ENDMEAS/
                        ANGLE VEC=<0,0,1>
                        SHOW HITS=YES
                        ENDMEAS/
                        ... Delete to here.
                        ******Call sub routine here SubroutineTest(X,Y,Z)
                        MOVE/CLEARPLANE
                        MOVE/CLEARPLANE
                        MOVESPEED/ FAST
                        COMMENT/REPT,
                        ~~1 INFORMATION:
                        When you dimension your features here follow example from post #5 to replace "CYL_D20" with the same naming convention in post #5.
                        COMMENT/REPT,
                        Position of HOLE-1.
                        COMMENT/REPT,
                        Position of CONE-1.
                        • Kp61dude!
                          Kp61dude! commented
                          You'll have to pass down XYZ values via the sub call if your want the features to be measured in different places.
                        Part routine call would look like this:
                        CS1 =CALLSUB/PART1_GEO,C:\Users\Public\Documents\WAI\PC-DMIS\2015.1\Subroutines\Subroutine_Dimensions.PRG:0,0,-.065,2.5,,
                        Subroutine like this:
                                        MYX =  : <-- THATS THE VARIABLE. INPUT VARIABLE(THIS HERE IS A COMMENT),
                                        MYY =  : INPUT VARIABLE,
                                        MYZ =  : INPUT VALRIABLE,
                                        MYI =  : INPUT VARIABLE,
                                        MYJ =  : INPUT VARIABLE,
                                        MYK =  : INPUT VARIABLE,
                                        MYDIA =  : INPUT VARIABLE,
                        CYL6       =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,MIN_CIRCSC
                                    THEO/<MYX,MYY,MYZ>,<MYI,MYJ,MYK>,MYDIA
                                    ACTL/<0,0,0>,<0,0,0>,0
                                    TARG/<MYX,MYY,MYZ>,<MYI,MYJ,MYK>
                                    ANGLE VEC=<1,0,0>
                                    DIRECTION=CCW
                                      NUMHITS=4,DEPTH=0.9,PITCH=0
                                      SAMPLE HITS=0,SPACER=0
                                    SHOW HITS=NO
                                    ENDSUB/
                        this would measure a circle at X: 0, Y: 0, Z: -.065, D:2.5
                        The more inputs in a feature the more variables you'll need to define everything if you want something other than default.
