LOOP Position?
  • LOOP Position?
    USE LOOP
    WHY Position together
    Question and picture are both unclear.
    PC-DMIS 2016.0 SP8
    Jeff
      Is the position dimension inside the loop or outside.
      If outside you need to use arrays in your dimensions and create a dimension for both.
      A[1] for the first loop position
      A[2] for the second looped position
        In your nominals spot, for X and Y, instead of 0 and 1.075, put [YOUR FEATURE NAME].TX and [YOUR FEATURE NAME].TY when dealing with loops.
          Is position In loop
          The entire size and evaluation are in the loop
          Isn't that okay?
            Means after using the loop
            The data is very strange when assessing
            If I want to measure 4 things in a row
            How should I set the loop
