Does anyone know how to permanently disable the virtual keyboard so it will not open every time I launch PC-DMIS? I have turned it off under the view tab but it still pops up when I launch PC-DMIS or open a new program. This is extremely annoying!
Virtual Keyboard
There is parameter available for the pcdlrn32.exe that starts up automatically the virtual keyboard. This parameter is the /VK. This came in with the PCDMIS ONE product and automatically set on the pcdmis shortcut if you installed PCDMIS ONE.
You can check then in the shortcut of your pcdmis application (I do not know where you run it from if is it by the programs menu or if you have your own custimized icon on the desktop) in any case you can check this out:
1) Rightclick on the menu item or the icon you use to launch PCDMIS and select properties from the menu.
2) In the target field aside to the pcdrln32.exe be sure that the /VK parameter is not present. In case it is in you can remove it and hit on OK.
by vpt.seLike the title says...
Does anyone know of a way to have an application or script to run upon open an existing partprogram or creating...-
Channel: PC-DMIS Code Samples
09-11-2008, 09:57 AM -
by NMC_CMMRecently, we've added another user/login to the CMM computer.
When PC-Dmis starts on the new login it pauses briefly then tries to create...-
05-15-2012, 08:50 AM -
Good morning everyone, in the laboratory there is a Pioneer CMM with Pc-Dmis 2019 R2 and Pc-Dmis 2020 R1 installed, Windows 10 with the latest 2004 update...
07-08-2020, 09:28 AM -
by bsacmmI am at a new shop and the cmm has not ran for a year. We hooked up the computer and got the computer to connect with the machine. I can only open old...
02-13-2009, 12:03 PM -
How To Create Buttons "ICONS"
Today I learned how to create my own personal icons
and I wanted to share it with you guys.
Channel: Tips & Tricks
12-09-2018, 11:48 PM -
