Code!!!!!!!
  • Code!!!!!!!
    What does the code look like if I want to take 3 individual points in the same spot that I measured in manual mode.
    Ex. 1)measured 3 points manually on top of 3 jo-blocks
    2)pnt4 = pnt1.x, pnt1.y,0,0,0,1 does not work for the 3 dcc points. it would in MM4 but I know I'm in PCDMIS
    Create an auto vector point. Then in the edit window edit the target values to read pnt1.x,pnt1.y,pnt1.z,0,0,1
      Use a SURFACE Point instead of a vector point and use RELATIVE measure.
      You then set the feature to the same nominals as the manual point you took, then set the relative measurement to all 3 axis on that manual point.
        I use that method all the time, and it works fine for me.
          Which method?
            I've used both, but I prefer Matt's method...
            PCDMIS 2012
            Windows Office XP
              I use Matt's method with surface points.
              B & S XCEL 7-10-7
              Sharpe32 Controller
              PH10MQ & ACR1 Toolchanger
              TP20 & TP2 Probes
              Pcdmis CAD++ 3.7mr3, 4.3mr1, 2009mr1, 2010mr1
              Datapage RT 3.33
                Matt I would like to try this do you have a small sample you done you could send out.....
                  P001       =FEAT/POINT,RECT
                              THEO/638.968,-57.335,-666.543,0,0,1
                              ACTL/638.968,-57.335,-666.543,0,0,1
                              MEAS/POINT,1
                              HIT/BASIC,NORMAL,638.968,-57.335,-666.543,0,0,1,638.968,-57.335,-666.543,USE THEO = YES
                              ENDMEAS/
                              MODE/DCC
                  P002       =AUTO/SURFACE POINT,SHOWALLPARAMS = YES
                              ACTL/638.959,-57.35,-666.542,0,0,1
                              TARG/638.968,-57.335,-666.543,0,0,1
                              THEO_THICKNESS = 0,RECT,SNAP = NO,$
                              AUTO MOVE = NO,DISTANCE = 5,[B][U]RMEAS = P001,P001,P001[/U][/B],$
                              INIT = 0,PERM = 0,SPACER = 0
                  Then, no matter WHERE you take that manual hit, the DCC hit following it will be in the exact same place, THANKS TO RELATIVE MEASURE!
                  The relative measure is kind of a drop-down in the auto feature dialog box for SURFAEC point (not vector point, but without any sample hits, a surface point is EXACTLY the same as a vector point).
                                MEAS/POINT,1
                                ENDMEAS/
                                MODE/DCC
                    Thanks Matt - I will print this out for future referance.....
