I'm running 3.5 r2. I'm modifying an existing program, which has file output commands to an excel spreadsheet. All the dimensions are profiles, but I need to output a distance dimenision. Can it be done?
Thanks
MrComment is right, we won't know for sure until we see an example.
But, if they are outputting with File/IO commands, there's a good chance they are using variables to do so. An example of this (pseudo-code) would be
File/Write, PROF1.M
where PROF1.M is the profile from the dimension command. So, in theory, you would need only to change the object being report, to something like this -
File/Write, DIST1.M
Disclaimers: I do not have PC-DMIS running right now, so I can't check the syntax, that is why I said pseduo-code. It could be DIST1.Meas or some other extension, and of course the base name depends on your program program ID convention. Hopefully, you'll get the idea. In any case, if you post some (or all) of your program, we can be sure to provide a better answer.
Hi, I use the TEXT output for the measurement report, but I want to rearrange the lay out. At the moment I have a feature and then underneath the nominal...
I would like get the number to be used for the file extension of the output file. I can read in pc-dmis basic help that you can set in an object "part.editwindow.setprintoptions",...
My goal is to run a program an have my report direct itself into a file on the computer. Now I can do this through the printer option but I have no control...
