I thought this had been passed on, maybe not. I've been doing this for a while by doing the following.
1) Manualy measure the ID, or OD where you want it to move around. "This creates MOVE/CIRCULAR"
2)Change the number of points you want it to take.
3)Change the diameter so that it will run in the middle of your slot & depth so it will hit the bottom.
4)Over ride the circle into a plane.
Sounds like a lot but really quite easy and quick.
And it does compensate in the correct direction.
Give it a try looks sweet as it goes around.
