http://www.wilcoxassoc.com/public/PC...lease/2018_R2/
Release Notes - 2018 R2 SP3
• PCD-141323 - Corrected the issue where the Quick Fixture buttons were not
maintaining their highlighting.
• PCD-145242 - Corrected the issue where PC-DMIS was not recognizing the
user-selected modes on the toolbars.
• PCD-145623 - Corrected the issue where PC-DMIS drew the Clearance Plane
paths in the wrong orientation.
• PCD-146884 - Fixed the issue where PC-DMIS would crash if Optimize Path was
running and you shut down PC-DMIS.
• PCD-147399 - Fixed the ability to click on a feature label and open the Auto
Feature dialog box.
• PCD-147480 - Corrected the issue when the Tracker Overview Camera was
clicked On, the machine would be in a "Not Ready" state unless you take a hit
while on the Camera screen. This was an issue with the Leica interface 40x
Tracker.
• PCD-148192 - Corrected the issue where PC-DMIS disables the middle mouse
wheel when you square up the CAD image.
• PCD-149828 - Corrected an issue with Optimize Path that could destroy the
contents of the Edit window. This only happened when you clicked Cancel
followed by Undo.
• PCD-150013 - Corrected an issue when saving back to versions before version
2015.1, not all the global measurement routine variables would be read into PCDMIS
when you run that measurement routine, even though the command data
would be correct.
• PCD-150164, PCD-152744 - Corrected an issue where the default print file type
could change without user intervention.
• PCD-150240 - Fixed a bug that puts PC-DMIS in a state where you cannot select
CAD surfaces after you box-select features and then select a Create Dimension
information box.
• PCD-150246 - Corrected an issue that caused the Excel output to start at 0
instead of 1.
• PCD-150622 - Fixed an issue with the Enable Interpreter that caused PC-DMIS
to crash when executing a Basic script.
• PCD-150832 - Fixed an issue that affected scan commands where PC-DMIS
would insert move points in the wrong locations.
PCD-150834 - Fixed an application error when you cut a feature from the Edit window that you are using as a relative feature for a Laser auto feature.
• PCD-150870 - Corrected an issue where the COP vector was not correct if you rotate the probe head. The issue was that PC-DMIS stored the pointcloud stripe vector in the alignment coordinate system instead of machine coordinates.
• PCD-151205 - Fixed an issue that caused PC-DMIS to crash when you change the Vision feature type in the Edit window.
Feature dialog box.
Tracker.
followed by Undo.
would be correct.
information box.
instead of 1.
