When you in the graphic window and you double click on a label you get a dimension info box with the dim,tol,nominal and etc. on the screen. I would like to use view sets with the part and dimension printed. Is this a good visual for the opertors, because now has now to take the blueprint to decifier the prinout but if I could give him a picture of the part with feature labels I think this would be better. Any input will be greatly appreciated. See picture attached. double clicking on the label is as far as I got.
Dim Info / View sets
There are a lot of ways to attack this. I just use the label that has the feature name. I typically use feature names that are similar to what the drawing calls out. BUT, most of the drawings I use are for multiple sizes of a family. My feature names can be DIAM A , DIAM B, etc. I have also used the ballooning that I used on a First Article.When in doubt, post code. A second set of eyes might see something you missed.
I have no suggestions on your question but...
I did notice from your screen capture that you are running 3.7 MR2. I would suggest that you strongly consider upgrading to 3.7 MR3. It is much more stable than MR2 and there are many here who like it a lot.
by CFisherI've got 2 screens and things still can become a mess. (2011MR1)
I dedicate the model view to its own screen when programming but after I build...-
09-26-2012, 02:01 PM -
by Kev HIs there any way of hiding dimension labels that are not in view? I want to print graphics but all the labels are in view no matter which way i orbit...
05-10-2017, 05:17 AM -
by Mike N.Anyone using 4.0??
I use it at another job and would like to change the amount of tags that are viewed in the graphic window.
I...-
06-13-2006, 09:55 AM -
by oriental_sunWhat does this mean? I havent ever noticed it before and was curious.
06-22-2012, 12:50 PM -
by ADAM WALLACEHi all, been awhile! I'm writing a generic program that measures a different bolt circle diameter depending on some flow control conditions. I am trying...
07-19-2017, 03:07 PM -
