Calibrating Angles for a Program
  • Calibrating Angles for a Program
    I am working on a project where they want me to calibrate only the angles that are used in the program. Where I am getting a confused is to how to do this. Write the program and then set up the angles using a variable and placing them in the beginning or what?
    Here's my code so far.
    ALIGNMENT/END
    MODE/MANUAL
    FLY/ON
    TEMPCOMP/METHOD = AUTOMATIC,MATERIAL = Calibration Sphere Steel,CTE=11.5
    ,SET WARNING LIMIT = TRUE,MINIMUM = 18,MAXIMUM = 22
    ,PART SENSOR NUM=DEFAULT,X SCALE= 20,Y SCALE= 20,Z SCALE= 20,PART TEMP=20
    LOADPROBE/SLOT_5
    CAL_SPHERE =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
    THEO/<23.2267,-5.0046,9.8822>,<0,0,1>,1
    ACTL/<23.2267,-5.0046,9.8822>,<0,0,1>,1
    TARG/<23.2267,-5.0046,9.8822>,<0,0,1>
    START ANGLE 1=0,END ANG 1=270
    START ANGLE 2=90,END ANG 2=90
    ANGLE VEC=<1,0,0>
    SHOW FEATURE PARAMETERS=YES
    SURFACE=THEO_THICKNESS,0
    MEASURE MODE=NOMINALS
    RMEAS=NONE,NONE,NONE
    AUTO WRIST=YES
    GRAPHICAL ANALYSIS=NO
    FEATURE LOCATOR=NO,NO,""
    SHOW CONTACT PARAMETERS=YES
    NUMHITS=10,NUMROWS=3
    SAMPLE HITS=1
    AVOIDANCE MOVE=NO,DISTANCE=0
    SHOW HITS=NO
    CALIBRATE ACTIVE TIP WITH FEAT_ID=CAL_SPHERE, QUALTOOL_ID=CAL SPHERE, MOVED=NO
    AXIS THEO MEAS DEV STD DEV
    X < 0.0000 23.2267 23.2267
    Y 0.0000 -5.0046 5.0046
    Z 0.0000> 9.8822 9.8822
    DIAM 5.0000 1.0000 4.0000 0.0000
    Thanks for any help on this.
    Darroll
    2018R2
    I think you could do it by selecting used angles in the probe window, then create a paramater set with them and use an auto calibration recazlling this parameter set.
    From the Core manual :
    "The Mark Used command button is found on the Probe Utilities dialog box.
    This option automatically searches the current measurement routine for AB angles. PC-DMIS then adds any AB angles that are found to the current probe configuration."
    JEFMAN
    PC-DMIS Ultra Guru
