Multiple Sphere Calibration
  • Multiple Sphere Calibration
    We do a lot of probing with star probes and other oddly configured tips and we're looking for a better alternative than moving our calibration sphere frequently. We are currently using a 1" sphere in a 30 degree angle base and frequently move it vertical or to 45 degrees. Would anyone recommend a 5 sphere setup.
    As far as I understand, you would be fine with 2; at least one being offset by 45 degrees or something. There is a dual ball calibration artifact that should take care of measuring the entire start probe, at least.
    May I ask why you're looking into 5?
    Edit:
    https://www.pcdmisforum.com/forum/pc...ed-calibration
    https://www.pcdmisforum.com/forum/pc...-changing-tips
    These two links should explain more in depth what I'm referring to
      Maybe something like this would do? I'm getting our tool room to make this up in the coming months.
      It will allow a full qualification of the standard tips and the star probe in one program with no adjustments to be made
      qual tool.JPG .
        Edit:
        The Quality Manager found it and thought it provided the most flexibility.
          2 sphere's is possible that I've seen, however it is mostly done with 3 spheres. concept for each:
          2 Spheres: 1 sphere pointed Yplus/Zplus(+45º), 1 sphere pointed Yminus/Zplus(-45º). Vectors would be the .7071's respectably (Or 1 sphere that can be rotated 180º about Z in-between)
          3 Spheres: 1 sphere pointed Xplus(90º), 1 sphere pointed Yplus(90º), 1 sphere pointed Zplus(0º)
            InspectorJester: Thanks, we did wind up going with the 2 ball artifact at 45 degrees.
