It would be great if the powers that be at hexagon would incorporate into a future release of PC-DMIS an AUTO HEX feature. I just got thru measuring a external hex feature (.156" +.000/-.002) by taking three hits per side, creating lines from those side hits, then inscribing a circle into those lines, all so that I could establish an A-datum on the hex. It seem that an auto hex feature could be incorporated to make this a less cumbersome task. Is this too much to ask? Am I being unrealistic?
Hexagon, an auto Feature I could use...
Originally posted by d.evans View PostIt would be great if the powers that be at hexagon would incorporate into a future release of PC-DMIS an AUTO HEX feature. I just got thru measuring a external hex feature (.156" +.000/-.002) by taking three hits per side, creating lines from those side hits, then inscribing a circle into those lines, all so that I could establish an A-datum on the hex. It seem that an auto hex feature could be incorporated to make this a less cumbersome task. Is this too much to ask? Am I being unrealistic?sigpic
Yes. The polygon auto feature was added in version 4.0 and above. Here's a screenshot I uploaded to this post when it was brought up before: http://www.pcdmisforum.com/showpost....0&postcount=24Jared Hess - Techwriter @ WAI
[View Reporting Tutorials Here]
Hi,
I'm trying to tweak my program with the auto feature. I have four threaded holes that I'm trying to tweak, so the probe won't hit the part. Can someone tell me what would be the best way to tweak my program, so I won't need to redo my steps?
Thank you.
Originally posted by Paul Sarrach View PostWhy are you waiting for 4.2? What do you mean?
G'day Folks,
Here is another idea, that I would like to see; Internal Corners.
I have had a need for this several times in the past. When using version 3.7mr3, I was told that I should be able to use the corner function and alter the vectors.
That did not ever work.
Blesssings,
ZydecoPetesigpic
Thank you.<internet bumper sticker goes here>
I have made a 3 point plan on a cad model using the auto feature, when i run the program after taking 3 points it wants more points, and i can not end...
12-29-2014, 04:31 PM -
by pnivenPHP Code:
[HTML]Help File[/HTML]
Without using CAD Data for an Auto Circle
To generate the circle without the use of CAD data:
Take three hits on
05-20-2008, 11:34 AM -
by Jace7420I have a part with 40+ holes that I just took 3 hits on each hole as to quickly program it. I went back and changed the hits to 5 hits, but i didn't...
11-18-2008, 07:06 AM -
by jeep26Is it possible to do this?
I want to measure a circle with auto feature and take 10 hits. Say one one of the hits are bad (burr). Can PCDMIS...-
01-28-2010, 06:21 PM -
by SuperBhello all---having a BRAIN CLOUD---- when measuring a circle in Pcdmis i have been told that the larger the DIA. the more more hits you want to take....
11-07-2013, 11:59 AM -
