I got a problem I'm trying to find a solution to.
I attached a couple of pictures to try to help explain.
I have to scan some features in a different alignment then what I have to measure all of the points in the scan relative to. In the first picture the Scan's "Findnoms" function finds the closest CAD nominal relative to the alignment the CAD was in when the Scan executes, which I'd expect this. However after I change to the final alignment where I expect to export all of data points out to. I noticed that the Theo value is no longer valid (reference the second picture). So what I want to do is force all of the points to do a "Findnoms" in this second alignment, because the first Findnoms is actually unimportant to me. (Im using v4.1 in this program)
