I am measuring a symmetrical part. I need to flip (rotate) the CAD model about the x-axis 180 deg, so when i measure the same features on the opposite end of the part, they are recognized in dmis, on the model, on the opposite end of the part. I do not need to re-ailgn because the part will be physically re-aligned in the exact same postition. I think this is possible...I have already searched these forums and haven't found solid answers...
Need to flip CAD model in Z
Originally posted by afenner View PostI am measuring a symmetrical part. I need to flip (rotate) the CAD model about the x-axis 180 deg, so when i measure the same features on the opposite end of the part, they are recognized in dmis, on the model, on the opposite end of the part. I do not need to re-ailgn because the part will be physically re-aligned in the exact same postition. I think this is possible...I have already searched these forums and haven't found solid answers...
FILE ~ OPERATIONS ~ MIRROR to mirror the entire program, cad and points
EDIT ~ PATTERN select what you want to do, in this case, flip the Z)
then COPY all the features, then EDIT ~ PASTE WITH PATTERN
OPERATIONS ~ GRAPHICS DISPLAY WINDOW ~ MIRROR to mirror just the cad data.sigpic
So you have one end of the part program created and once thats finishes you want PCDMIS to stop so that you can rotate the part and then check the same features over again?
Since the part is symetrical, why is it necessary to rotate the CAD model 180 degrees first? One option could be to place your program in a loop which would execute twice, but rotate the about the X axis 180 degrees. This would make your features show up in different locations on the screen without rotating the CAD model.Mr. Comment
SCIROCCO-NT 13-20-10
Actually I like Matt's idea of mirroring the program, you can copy and paste that and then never have to screw with the loops. Which are a pain the bum with PCDMIS.Mr. Comment
I'm gonna try the mirror idea first, i have only toyed with looping and haven't really implemented the use of loops in my programs yet, and I haven't been officially trained on looping yet. I may try that in the future.
thx fellas...
Aaron Fenner
Quality Engineer
PC-Dmis v4.3
B & S Global Status 7.7.7
6 years xp 32-bit
Originally posted by afenner View PostI'm gonna try the mirror idea first, i have only toyed with looping and haven't really implemented the use of loops in my programs yet, and I haven't been officially trained on looping yet. I may try that in the future.
thx fellas...sigpic
I would do a Paste with Pattern. Use zero offset in X, Y, and Z as you say the part will be in the exact same place. Then rotate about necsessary axis as part of the Pattern Paste. No surprises.Bill Jarrells
by Gil-LeiriaHi everybody,
This is my first post and I am new working with PC-DMIS.
Can I mirror features in a part program with PC-DMIS 3.7...-
04-10-2006, 08:46 AM -
by RussLV3.7 MR2 - Windows XP - Catia V5 DCI
As Shown Program: Cad X+ = Mach Z-, Cad Y+ = Mach X+ and Cad Z+ = Mach Y-
Manual iterative align to...-
04-06-2006, 09:14 AM -
by blind829Is there anyway to "mirror" a program, but not about the X,Y or Z axis? I'm checking a rather large gage that checks symmetrically opposite...
07-30-2009, 08:50 AM -
by TLANIGANHello is there a way to program the RH side of a part and copy the program for LH side and , and change vectors to save time. We are using the cad models...
Channel: PC-DMIS Portable
10-30-2012, 02:01 PM -
by NfiskIn our shop we are building two parts. One is a left hand part and the other is a right hand part. Essentially a mirror image of each other. I have...
05-16-2008, 03:59 PM -
