This has happened a few times in the past (maybe 4 times in the last year). Now, it has happened twice in the last two days. While moving manually with the jog box, the machine will 'jump' in the +y direction. It will only move an inch or so and then be back to normal. Needless to say, it scares the poo out of the operator. After it does this, it kicks up an error that reads "Z-axis excess lag error"
According to previous posts, that lag error is because of movement that is unexpected. I find it odd that it is a z-axis error instead of a y-axis error. I suppose it could be moving in both y and z but more easily noticed in y. I believe the lag error is a result of the jump so I think if I fix the jump, the error will not occur.
Anyone know what could be causing this jump? Do you think it could be the joystick going bad?
