Line/Curve Intersection bug (v4.2)
  • Line/Curve Intersection bug (v4.2)
    Constructed Points for Curve and Line Intersections.
    1. Theo values for the constructed point intersect the wrong curve. (They appear to be intersecting the Measured Curve instead of Theo).
    2. Assignments do not function when trying to address the constructed point. For example : ASSIGN/V1=PNT1.X does not work (instead it appears red though the syntax should still be valid).
    v4.2 Build Date: Mar 22 2007
    Mr. Comment
    SCIROCCO-NT 13-20-10
    Try pnt1.x.meas
      Nice thought, but that doesnt work for me either.
      Mr. Comment
        2 questions:
        Did you make absolutely sure that your assignment matches your feature name?
        Did you construct the assignment by going to insert - assignment - etc.? Or did you just hit enter at the end of a line of code and type assign...
          Operator Error (No Pun intended)
          Opps, my feature name had a deceptive character in it. My faith has been restored.
          "SCN20-22_IPNT192", I know better then to use operators in feature names.
          "SCN20_22_IPNT192", changed the name and the Assignments work now.
          Mr. Comment
