Does anyone know how to make a photo pop-up (prompt) during the running of a program?
Photo pop-up during program?
INSERT EXTERNAL OBJECT. Here is code from one of my programs.
Code:C2 =COMMENT/YESNO,Do you want to see a picture of the setup? IF_GOTO/C2.INPUT=="NO",GOTO = L2 Insert the external object here L2 =LABEL/
Last edited by John Kingston; 04-09-2007, 11:58 AM.When in doubt, post code. A second set of eyes might see something you missed.
I would suggest that you put in TWO (2) 'dummy' comments, then do the external object BETWEEN them. Some version of Pcdmis have problems with deleting external objects by themselves, you can't 'grab' them to delete them, but with a comment before and after, it is easy.sigpic
INSERT
REPORT COMMAND
EXTERNAL OBJECT
mark CREATE FROM FILE
the BROWSE for it
double click on the picture
click on OK
MARK the object as it appears in the EDIT WINDOW
There are 4 levels or 'marked':
not marked
outside of box 'highlighted'
inside of box 'highlighted'
both in and outside 'highlighted'
You want BOTH,sigpic
One thing you will find with this method is that it will "pause" your program and open the picture. When you are done looking at the picture, you have to click "continue" to finish the program.
I put all my setup pictures on one page and create a .pdf of it. That way, there is only one file to insert/open and it has several different views.
Originally posted by craiger_ny View PostI would say Hypereport but I see the OP uses 4.1, too bad. I think I was the only person that actually used and liked Hypereport. For pictures and set up interfaces and such. It sucked for post inspect but was great for what you need to do.
Then after creating the FORM go to...
INSERT>REPORT>FORM>. Save the form "as" somewhere you want them, and in the form is insert object(pretty little picture scene) See my screenshotsLast edited by JamesMannes; 05-18-2007, 02:09 PM.sigpic
Here's a smaple of the way I use photos....
PART NAME : 6565040-2
REV NUMBER : A
SER NUMBER :
STATS COUNT : 9
STARTUP =ALIGNMENT/START,RECALL:, LIST= YES
ALIGNMENT/END
COMMENT/DOC,NO,See tip configuration setup in C:\PCDMISW\Pictures\C3_SLOT4
COMMENT/DOC,NO,Mirrored by Daniel S Hudson 03/29/2007 08:00 AM
,Engineering Revision A
,Software Revision 3.7MR2
MODE/MANUAL
Q1 =COMMENT/YESNO,NO,IS TOOL_C3 LOADED
IF_GOTO/Q1.INPUT=="YES",GOTO = L1
LOADPROBE/C3_SLOT4
L1 =LABEL/
TIP/T1A90B180, SHANKIJK=0, -1, 0, ANGLE=180
PREHIT/ 0.2
RETRACT/ 0.2
MOVESPEED/ 75
COMMENT/REPT,.
,| McCauley Propeller Systems - All dimensions are to blueprint specification |
,| This program check the 6565040-2 Bellcrank (RH) Arm Detail - W.S. 160.95 |
C1 =COMMENT/INPUT,YES,'Serial Number'
C2 =COMMENT/INPUT,YES,'Work Order Number'
C3 =COMMENT/INPUT,YES,'Machine Number'
C4 =COMMENT/INPUT,YES,'Operations Number'
C5 =COMMENT/INPUT,YES,'Operator Intials'
EXTERNALCOMMAND/NO_DISPLAY, NO_WAIT ; C:\PCDMISW\PICTURES\IEXPLORE.EXE C:\PCDMISW\PICTURES\6565040-1-2.JPG
COMMENT/OPER,NO,With part mounted on fixture as shown
,Take 3 points on Datum -A-.....
MPLN1 =FEAT/PLANE,RECT,TRIANGLE
0Last edited by AuRules; 04-09-2007, 12:44 PM.sigpic
Originally posted by AuRules View PostHere's a smaple of the way I use photos....
0sigpic
Originally posted by JamesMannes View PostI don't have a problem with the way you have presented your pictures, I would make comment though on your ability to add some text to the setup photos. In a FORM, at least you can add text, and edit that text. If for example I add my text via SNAGIT(screen capture software) it is made a part of the .jpg and you cannot remove/change it afterward.
I just add the text in Microsoft Paint and then save the text and the picture together. Then open it as one in my program. The comment after the external command is to stop the program and give the operator time to close the picture.sigpic
by firehausI'm attempting to insert a command to open up an instruction page for our Operators. Currently, an instruction page with pics and instructions are written...
05-09-2013, 04:27 PM -
by JigneshYou can go Insert---Report command---external object to insert picture of work piece with fixture installation in program. Someone wrote in my similar...
08-12-2016, 01:31 PM -
by vektorExternal objects?? does it work as it should?
I am running 3.5mr2 and it not working
My goal is to get a picture of a Cpk diagram...-
10-10-2006, 01:12 AM -
by pdqgeorgeI would like to open a pictoral setup sheet at the beginning of program execution, the preferred format being .pdf (as opposed to .doc). I tried FILE/OPEN...
11-01-2011, 05:29 PM -
by AAP_CMMI insert an External Object into my Edit Window on PC-Dmis 2011 MR1...its an excel spreadsheet that i would like to have print off with the rest of the...
12-10-2019, 04:58 PM -
