Reporting...
  • Reporting...
    When I run multiple parts, say a 100 piece run, it want's to report every part on one report. I want it, by default, to report just the one part I had just run... NOT including previously run parts.
    As it is now, when the part is done running and the dialog comes up to save the report, I cancel out of it. Then I view the report and have to click the "View Report Mode" button which flushes out the previous runs data and gives me just the part I had just run, and that's what I want it to do by default.
    TIA
    -Bill
    PC-DMIS 4.2 MR1 - Global Image 7107 - PH10MQ - SP600M
    Put your print command line before logic takes you to next part
    Down side header is not there after first part, I have never resolved this
    I have used looped counters to add report comment line with sequencing of parts or whatever other information you want on the report for this to track reports to particular parts relevant info
      I don't have a print command line or logic that takes my next part.
      I'm using defaults from the program.
      -Bill
      • KIRBSTER269
        KIRBSTER269 commented
        Power, I used to have a script refresh report. Don’t have it anymore, maybe do a search. I’ll do the same in the meantime. This was before print commands
        Maybe
        https://www.pcdmisforum.com/forum/pc...7-blank-report
      • dmis100
        dmis100 commented
        Sub Main
        Dim App As Object
        Set App = createobject("pcdlrn.application")
        Dim Part As Object
        Set Part = App.activepartprogram
        Dim Cmds As Object
        Set Cmds = Part.Commands
        Dim Cmd As Object
        Set ReportWindow = Part.ReportWindow
        Dim ReFrw As Object
        Set ReFrw = Part.ReportWindow
        'Full Report Mode
        'lngRetVal = ReportWindow.FullReportMode()
        'Last Execution Report Mode
        lngRetVal = ReportWindow.LastExecutionReportMode()
        'Report Refresh
        ReFrw.refreshreport
        Set ReportWindow = Nothing
        Set EditWindow = Nothing
        Set DmisPart = Nothing
        Set DmisApp = Nothing
        End Sub
      The report prints what is in the execution list. Clear the list between your partial executes. File/Reset execution list. The is also a registry setting to automatically do this but I can’t remember what it is at this time.
        In file/Printing/report window print setup try to set it to owerwrite or auto
          How are you executing the program?
          Run from cursor?
          If you execute the whole thing (Execute button or Ctrl+Q) it clears the execution list.
            I'm doing a CTRL-U on the line where it goes straight to DCC. All I wanna do is have it report the last run.
            -Bill
            • NinjaBadger
              NinjaBadger commented
              Just unmark everything prior to that and do a ctrl+q instead.
              (Overwrite will actually just overwrite the report file entirely)
            Ahhhhh... overwrite!! I'm going to try that!! I'll report back. THANKS!!!
            -Bill
              The only ways to do this are to
              1) perform a full exection or
              2) clear the execute between partial executes or
              3) add/execute a PRINT command to output what was currently executed.
                This is how I print reports.
                1. It doesn't matter if I execute from CTRL+Q, CTRL+L, etc, as long as the machine recognizes at least ONE command beforehand (e.g. a move point, a feature, a clearplane, etc.)
                2. Insert a print command after your features but before your dimensions.
                3. Ensure this print command prints to nothing (no printers, files, excel, etc) and is set to DELETE_INSTANCES
                4. Insert>Report Command>Report Label.. The default is FILE_HEADER.rpt
                5. Continue with all of your dimensions you'd like to output onto the report, respective report comments and the like.
                6. Insert a second Print command, printing to your printer or a file or whatever.
                7. Set the second Print command to KEEP_INSTANCES.
                8. Try, try again
                  Are you using a loop function for measuring multiple products? Or Inspect?
                    This is why I hate pcdmis, simple things are a pain in the ****. been using it for 15 years and it's the worst software I have had to endure.
                    just let us set "view report mode"!! and set it as default in settings.
                    not everyone gets to do a ctrl-q and run from the top without interruption.
                    I'm starting to think they have had the same dinosaurs working at pcdmis for 20 years that refuse to change and make a software for the year 2018...
                    • davehocum
                      davehocum commented
                      And when Hexagon does update PC-DMIS it's like they restored a old car to be like a New car in an incomplete way. I call PC-DMIS the forever beta software.
                    BTD_CMM
                    8. Try, try again
                    This works for me very well. Try this
                    Or demo a new software maybe lol
                      no need to re-post a quote that I already saw above
                      I also use Polyworks, a modern software made for the modern world. lol maybe you guys should try it too.
                      • davehocum
                        davehocum commented
                        Polyworks is another software I have been very interested in. How does Polyworks GD&T compare to PC-DMIS GD&T for reporting?
                      BTD_CMM You are making a great name for yourself belittling other people and bashing PC-DMIS. You have 3 posts on this forum and 2/3 of them are in this thread and all of it is a bunch of complaining. Go somewhere else with it.
                      • KIRBSTER269
                        You’re like someone I would almost admire
                      • KIRBSTER269
                        ..........almost
                      • bfire85
                        bfire85 commented
                        KIRBSTER269 I almost wish I could say the same about you. Almost...
