Cannot use row 1 in Excel output for my header?!
  • Cannot use row 1 in Excel output for my header?!
    Hi All,
    I would like to have my header data in row 1 in Excel. In the print command I change in "Excel output" the row of the header to "1", but when I press default and then OK, it is changed back to row 2...
    Does anyone know why I cannot change the Header row to row 1?? My other pc does not have this problem.. The version is 2017
    Try changing it to 0 or moving the header to Row 2
      it could be the P2X file is not being updated correctly in that version. You should have a P2X file extension with the name of the PRG file you are using. You can edit that file (via NotePad) to set the value
      HEADER ROW=1
      As a side note it seems to be OK using v2018r1.
        It helped changing the P2X file, thank you!
