I've been using dual monitors for years and finally have an issue. We got a second CMM from one of our plants that closed down and they sent it with one monitor. I finally got IT (bane of PCD programming) to give me a second monitor. It doesn't match the first monitor (resolution or size) but the other CMM's monitors don't match either. When I try to drag PCD (bottom right corner of program window) to the right hand monitor it pops back to the left. I've never had this happen before HELP.
Dual monitor issue
Originally posted by DeWain Hodge View PostI can drag from one monitor to the other but not stretch across both.
For me, I go to NView Desktop Manager, under Windows Manager, Enable window spanning across multiple displays, and you may want to turn on Enable child window spanning across multiple displays.
But that is for my card, your card may vary.
Double check the position of each monitor in relationship to each other (if that makes any sense). On Windows 7 right click your desktop click screen resolution. Once there you'll see your monitors (each monitor identified by an integer), you can drag them around to match your physical set up. If one is smaller than the other...that one will sit a bit higher or a bit lower than the bigger one, etc.
Or just make your PCD window small vertically (like an 1" tall or so) and drag horizontally to the other monitor. I think, what's happening is a large square to a small box effect is what's stopping you or one monitor is sitting way up/down and PcD window is hitting a invisi-wall.Last edited by Kp61dude!; 09-14-2018, 11:29 AM.PcDmis 2015.1 SP10 CAD++
Global 7-10-7 DC800S
- 1 like
Another thing, in order to span, I am pretty sure that the monitors do NOT have to have the exact same resolution, BUT, I think they MUST have the same "up/down" number of pixels. I have 2 different size monitors (one wide screen, one normal screen) but they both have the same up/down resolution. One is 1920x1200, the other is 1600x1200.sigpic
I normally move just the edit window out of the PCDMIS box entirely to stretch screens.
Have you tried to move just the edit window by click-holding in top bar of edit window and dragging over?
Whatever gets it done, get other display settings the way you prefer, then save it as a window layout.
- 1 like
That will be a graphics card setting (if the card will allow it).
But that is for my card, your card may vary.DeWain Hodge
by jeff595We just updated from 3.7 to 4.2 and cen't seem to get our report window to drag to our secondary monitor? It worked fine in 3.7, in fact you could drag...
05-10-2008, 03:00 PM -
by BSchwarkWhat vidio card was need to use a double monitor set-up? I tried it before and had some issues with my current set-up.
BS-
03-08-2006, 11:01 AM -
by Ironman187Hey all, I just got a second monitor for my setup, I wanted to set up PCDMIS so that the main window (edit window, cad window, and tool bars) would stay...
07-18-2014, 11:59 AM -
..Note that we are using a dual monitor system, if that matters at all ??? Anyway, have any of you guys had difficulty toggling the probe tool box back...
04-24-2008, 03:44 PM -
by TKOFaithI just added a second monitor to my workstation. I wanted to move the Graphic Display Window to the second monitor, but PC-DMIS won't allow me to do...
11-24-2015, 12:06 PM -
